Results 61 to 75 of 99
Thread: Hot rod V4s
03-28-2018, 06:29 AM #61
New Member
- Feb 2017
- sc pa
03-28-2018, 07:01 AM #62
Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,380
- 1081
- 421
- 4796
- 2207
- 9 Post(s)
all true but the poster asked about the yam flywheel on aftermarket ignition, hence my question.
One day we might get a dyno back to back on swapping to yam ignition.
My guess the component quality is always better than the OMC so its covers other low output issues day in day out?
03-28-2018, 07:51 AM #63
5000 RPM
- Alabama
- 897
- 28
- 29
- 58
- 81
There is no horsepower gain going from Omc to Yamaha ignition.
03-28-2018, 08:07 AM #64
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
Stability is a +
03-28-2018, 08:08 AM #65
- Jun 2007
- 9,380
- 1081
- 421
- 4796
- 2207
- 9 Post(s)
03-28-2018, 08:11 AM #66
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
Strange, had a talk with an aftermarket ign guru. He said no Omc ign ever advanced ahead of the signal. Never, impossible. How do you say it's done?
03-28-2018, 08:24 AM #67
- Jun 2007
- 9,380
- 1081
- 421
- 4796
- 2207
- 9 Post(s)
There is a reason you need to set OMC timing at rpm but on a merc you can set it at cranking.
They behave opposite.
Put a light on an omc and see for yourself from max advance to max rpm
03-28-2018, 10:44 AM #68
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
Set any at cranking and you'll need to add advance to compensate for delay in travel of signal vs high rpm crank speed.
How does the Omc advance it ahead of the trigger signal. Does it do it with rpm reading and leading cylinder trigger, rotation calculations preset to set it off?Last edited by FMP; 03-28-2018 at 10:49 AM.
03-28-2018, 11:03 AM #69
my Yamaha ing. pulls timing out at haven't checked it lately best I can remember it was about 2 deg.
13 ft allison 75 omc
14 ft Allison
15 ft allison molds
17 ft tin fisher-marine 3cyl. omc
17' Allison ski boat
Grand Sport w/etec
Freddie Webb thanked for this post
Freddie Webb liked this post
03-28-2018, 11:33 AM #70
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
The mechanical linkage goes to a full position and stops or backs up a hair at WOT? If it stops full the timing lost is from the crank speed getting ahead.
upyours liked this post
03-28-2018, 12:06 PM #71
6000 RPM
- Sep 2002
- Solvang, Calif
- 1,459
- 78
- 29
- 160
- 156
Subscribed. Hey Freddie, causing trouble again as usual I see.
Gary
03-28-2018, 12:29 PM #72
5000 RPM
- Alabama
- 897
- 28
- 29
- 58
- 81
Gary Finch you taught me well
03-28-2018, 12:33 PM #73
5000 RPM
- Alabama
- 897
- 28
- 29
- 58
- 81
Gary Finch call me sometime. I did try to document every detail on every dyno pull on your engine and loved every minute of it. The problem with that is I can't remember anything! Lol the bat cave causes amnesia haha
03-28-2018, 04:20 PM #74
6000 RPM
- Sep 2002
- Solvang, Calif
- 1,459
- 78
- 29
- 160
- 156
Freddie it's CRS(Can't Remember Shix) or my favorite... "I've slept since then".
I talked to "Bat Man" recently, he said the OMC project might restart probably in May...of this year...I'm not holding my breath. LOL.Gary
03-28-2018, 05:02 PM #75
5000 RPM
- Sep 2008
- Mass
- 450
- 16
- 39
I have no idea what either the omc or Yamaha ignition does to timing after the throttle advance lever goes to max. I believe timing stays constant but due to electrical effects like coil saturation, ect this could vary some.
What I do know is what a proper programmable cdi will do. For example.
Starting timing will be between 5-10 degrees.
You will want this to stay low or same while put puting away from the dock or launch. Same for idle rpm. What's a good idle. I seem to remember 500-800rpm.
So let's say at 1000 rpm when you're starting to give some throttle you ramp up the timing. Maybe up as high as 35 degrees for poor combustion chamber xflow. How quickly you ramp it up will depend on how aggressively you want to launch and build torque. If you need to cruise off plane above idle you wouldn't want to ramp up timing too quick.
So say from 1000 rpm to 2500 rpm you ramp the timing up to 35 degrees.
This is where your launching the boat to get on plane. This is where the extra timing advance is going to help the most. Build more torque and overcome the extra weight your packing in your cooler.
Now the timing will probably stay flat for 1000 rpm or so at 35 degrees. Up to 3500 rpm.
Now your on plane and picking up speed. Now you start to ramp the timing back down(retarding) to a safe level for peak rpm. Say 20 degrees at 7000 rpm. Rpm can vary depending on your engine, how high it can turn. Timing will vary depending on what your engine likes. Depending on the compression ratio, and squish arrangements (for a looper) and fuel.
This all can be changed and tweaked depending on what your engine, boat and driving habbits demand.
So a proper ignition will both advance and retard the ignition timing.
If you add in a TPS. The ignition profile becomes reactive to throttle input making it even more responsive and tunable.
olboatman thanked for this post
