Results 1 to 15 of 20
    Apr 2014
    nj
    What type store bought acid to remove alum from sleeve
    In process of modifying three 2002+ 3 litres , changing port timing and ex chest work to 300x specs . Curious what type store bought acid removes or loosens aluminum transfer on 3 litre sleeves .
    Thx
    Attached Thumbnails Attached Thumbnails DSCN5683.JPG   DSCN5709.JPG   20160405_192757.jpg   20160405_192732.jpg   20160405_222200.jpg
    Pekin, IL
    Nothing eats aluminum faster than muriatic acid and you can get it at any hardware store. Caution must be used cuz it will also eat steel but a a much much slower rate. Also wear a good respirator and rubber gloves. The stuff puts off pretty rough fumes you really want to avoid.
    Rock
    Team Junk
  3. Likes Dave Strong liked this post
    Apr 2014
    nj
    Yes I know that is nasty stuff , I bought five gallon of it and dropped in some old Mercruiser ex manifolds as to de-rust inside , it looked like a witches brew white fog went thru the neighborhood , Had a 700 k home next to me , it was terrible and everyone was asking WTF
    Maybe I can dilute it
    Pekin, IL
    Don't dilute it. Just don't use quite as much. And try not to breathe.
    Rock
    Team Junk
    Apr 2014
    nj
    Thx , maybe ill use it to remove skid marks in my underwear
  7. Likes Capt.Insane-o liked this post
    May 2014
    Livingston, Louisiana
    I've used Q-tips to put it on with to control amounts being applied and keep from making a mess.
  9. Likes Forkin' Crazy, oldschoolltv liked this post
    Jul 2010
    edmonton Alberta
    Quote Originally Posted by LOSTINJ View Post
    It will work, but there won't be any fabric to skid on. Most Industrial Strength Toilet Bowl Cleaners are based on Hydrochloric(Muriatic) Acid. Same stuff your stomach excretes to digest what you eat
    Pekin, IL
    Exactly why I don't wear underwear.
    Rock
    Team Junk
    NE Louisiana
    Careful where you store it too. Crazy how the fumes will escape through the lid and or jug. I had a jug sitting on a shelf below a prop. Two weeks later I was having the prop repolished and started keeping the jug outside!
  13. Likes FORBESAUTO, David - WI liked this post
    Pekin, IL
    I have seen people try to remove aluminum build up in a cylinder without a total disassembly. They remove intake to get at rod bolts, remove rod and piston, and leave crank in place. Don't do it. It will ruin crankshaft.
    Rock
    Team Junk
    Feb 2005
    seattle
    be careful. it also does a number on concrete and grass. us plenty of water to wash off.
  16. #12
    Apr 2014
    nj
    good or bad for removal genital warts ?
    Pekin, IL
    Would take a real man
    Team Junk
  18. Likes 90 5.0 liked this post
  19. #14
    Aug 2012
    beaumont, tx
    can also get it at pool supply store....
  20. #15
    Sep 2015
    Twin Cities, Minnesota
    Murphys Law states that any time you use muriatic acid, outdoors or even in your garage with or without a fan, there will be a magical breeze that comes from nowhere no matter what and gives you a face shot of fumes just because it can.
  1. New member 1997 Jazz - I want to remove the engine . Do I need to remove jet first?
    By hornman in forum Posting Questions and Suggestions
    Last Post: 01-03-2013, 01:38 PM
  2. 2.5 sleeve clearence between piston and cast iron sleeve
    By great adventure in forum Technical Discussion
    Last Post: 07-05-2010, 07:29 AM
  3. Acid wash
    By flabum1017 in forum Technical Discussion
    Last Post: 01-14-2008, 07:15 PM
  4. Help!!-How to remove a steel sleeve to weld block
    By Valeroman in forum Technical Discussion
    Last Post: 04-07-2003, 11:59 AM
  5. Why remove LU and store separately???
    By cm21 in forum Technical Discussion
    Last Post: 12-07-2001, 06:58 PM
