				Results 1 to 7 of 7
		Thread: oil injection removal
	03-03-2018, 08:56 PM #1 Junior Member Junior Member- Join Date
- Feb 2005
- 29
 oil injection removalI have a Merc 220 Laser block that I am removing the oil injection from....I have seen threads here that talk about a block off plate for the oil injection pump hole. Are these home made or can I buy one? Either way let me know or if there is a link to a site that would be great to
 Thanks
 ttopp
	03-03-2018, 11:10 PM #2Pro Marine. Last time I bought them the o-ring was separate. Team Junk
	03-04-2018, 12:21 AM #3 5000 RPM 5000 RPM- Join Date
- Jul 2007
- Ms. gulf Coast
- 334
 pull pump and prep for premix, 3/4" freeze plug driven in with sealant, done.
	03-04-2018, 07:22 AM #4Oil Injection System RemovalThe mercury oil injection system is a popular item to remove, especially given its reputation for failure, and inability to deliver reliably after 6500 rpm.
 Remove oil resevoir, oil pump, mag pickup, pump drive shaft, then install plug in shaft hole. Remove oil hose off bottom of vapor seperator, plug hose, remove fitting on starboard side of the block where oil tank pressure hose is coming from, plug hole with pipe fitting either 1/8 or 1/4., Remove oil alarm box, and i think that's all. the plug for the pump shaft hole you will have to get from dealer. (12)
 Mercury part number for the plastic block off plate is 43453 and the O-ring for that kit is 32509. Jay Smith Racing Engines also has a billet kit for doing this.
 Finally it is recommended by several sources, that you keep the old oil pump gear on the crankshaft, as it provides crankcase volume, and if removed will cause that cylinder to be lean.
	03-04-2018, 07:58 AM #5Not a good idea, need to use the special plug. There is a brass bushing in the floor of the cylinder that the end of the oil pump shaft rides in. Once the shaft is removed there is a chance the bushing can come out, not good. The special plug goes all the in to hold the bushing in place.
	03-04-2018, 08:44 AM #6Pro Marine oil injection block off Part # 43453
 Pro Marine oil injection block off kit Part # 43456 (includes o-rings)death is certain; life is not
	03-04-2018, 09:09 AM #7 Junior Member Junior Member- Join Date
- Feb 2005
- 29
 Thanks for all the great info guys....I believe I have seen the Merc part on line before but would like to see the Pro Marine stuff as well.
 ttopp
  Mercury Tech: 0il injection removalBy Air Eddie in forum Technical DiscussionReplies: 2Last Post: 10-24-2009, 06:37 PM
  Oil injection removalBy Mean Dean in forum Props, Setup, and RiggingReplies: 1Last Post: 05-11-2009, 06:25 AM
  2.4 Oil Injection Removal ???By Mariner245 in forum Technical DiscussionReplies: 2Last Post: 05-12-2008, 12:45 AM
  Oil Injection Removal?By DOORSHOT in forum Technical DiscussionReplies: 4Last Post: 08-16-2007, 05:55 PM
  Oil Injection RemovalBy gw204 in forum Technical DiscussionReplies: 12Last Post: 11-02-2002, 10:20 AM
