Page 3 of 3 FirstFirst 1 2 3
Results 31 to 39 of 39
  1. #31
    Sep 2002
    Solvang, Calif
    I would listen to Al Stoker= racer.
    If it is a 3.6 with a 26 raker I would bet it is sluggish when you first hit the throttle and the nose goes up and then all of a sudden the engine starts to come on and it breaks loose. If so try drilling small vent hols in the prop until it accepts throttle good, you need to get the first movement to be quick so the nose does not raise. You may want to try a smaller pitch with a little tip cup and vent holes as well. The 3.6 does not like bigger pitch thru hub props.
    Gary
  2. Thanks racer thanked for this post
  3. #32
    May 2001
    Hickory NC
    5 Post(s)
    Dont ease it to 2000 just hit the throttle from idle and let us know
  4. #33
    Jun 2017
    fife scotland
    Quote Originally Posted by gfinch View Post
    I love my Bikini
  5. Thanks racer thanked for this post
  6. #34
    Nov 2004
    Here are some pictures of the propeller. I am planning to purchase the setback during this weekend to see if that solve the issue. Click image for larger version.
Name:	propeller pics 2.jpg
ID:	399153Click image for larger version.
Name:	propeller pics 1.jpg
  7. #35
    Jul 2002
    Las Vegas, NV
    Did you do what Al said? Just hit it hard from idle and see how it pulls out of the hole.
    With my Scarab (30' with twin V8's), the quickest way on plane was to go full throttle from idle. The motors would rev up to about 2400rpm or so and start the boat moving. Just before it would roll over, the props would break loose and rev way up. I'd pull the sticks back to hold the engines at 4500rpm and it would bit and go.
    Keith-
  8. #36
    People we are talking about a Boston Whaler, Wrong lower (wont need a nose cone), Motor needs to go lower (cav plate closer to bottom of boat), shouldnt need to ventilate the prop (with right setup and prop). Needs a 25" motor, probably doesnt have to go back further. We have many customers with this boat and non need setback. Of course they are not overpowering it but thats cause this is not a performance hull. Just my opinion, I think people are all over the place on this. Back to basics its a family boat for fishing and crabbing. Yeah it could go fast, anything overpowered will (might) at what expense?
  9. #37
    Nov 2004
    Well I don't live nearby the shore, therefore, I will need to take every step one by one. I expect to do some testing during the next weekend.
  10. #38
    Nov 2004
    Well team here is the update:
    I installed a 6” setback from bob’s (Backwards). And conduct the test with the same propeller. The engine is now like 1(1/2)” lower than before. With that, the boat planes like a normal setup. To me it seems that can go higher. However, because the boat finally planes, I noticed that the engine has some issues. Idle is good, check fuel pressure and it was higher than 5 PSI, check each carburetor and all of them has same spray pattern, change plugs, disconnect the power pack white wire(protection wire),and issue continued. The issue is that the engine does not go higher than 3500 RPM at Wide Open Throttle. Based on that, I will be focused in the electrical system (Time base, power pack, stator). I purchased everything new to avoid this kind of issue. All the electrical system is new from wiring to coils and the other electrical components. I will do some testing, let see if I finally enjoy the setup.
  11. #39
    Ft. Lauderdale, Fl
    start off with a full sync and link, timing adjustment, check spark on all 8, check compression.etc......................
  1. 1985 evinrude 150 idles great but wont plane
    By Brian Bownds in forum General Boating Discussion
    Last Post: 09-03-2016, 08:08 AM
  2. Motor shut off and priming difficulty
    By sailnaked6842 in forum Technical Discussion
    Last Post: 04-02-2015, 10:16 PM
  3. Mercury Tech: Difficulty cold starting '98 Mariner 175 Mag EFI outboard
    By MarkMuzzy in forum Technical Discussion
    Last Post: 06-08-2012, 08:16 AM
  4. OMC to Merc or Yami difficulty
    By HPjunkie in forum Technical Discussion
    Last Post: 07-17-2009, 08:00 AM
