Results 1 to 15 of 275
Thread: Mercury 1994 2.0L 150
02-16-2018, 10:15 PM #1
5000 RPM
- Oct 2008
- Plainville, CT
- 872
- 478
- 30
- 448
- 78
Don’t have much of the history on this engine other than it hadn’t been run for several years, and by the looks of the cowling, it had been abused before that. It came with the lower part of the airbox full of junk that oozed into the lower left carb, which I believe would be for cylinder #6. It looks like it may have been stored face down in a compost pile.
Right now I suspect that someone tried to run the engine without cleaning it out first and the junk got sucked in and locked up the engine. Attached are pictures of the evidence so far as it is being dismantled.
One question I have is can the front half be removed without pulling the engine off the midsection? Also, does the flywheel have to be removed as well? This is the first time I’ve needed to go this far in dismantling one of these.
02-16-2018, 11:21 PM #2
You will have to remove powerhead and flywheel. Those are good motors.
RockTeam Junk
Glastron1987 thanked for this post
Glastron1987 liked this post
02-18-2018, 07:17 PM #3
5000 RPM
- Oct 2008
- Plainville, CT
- 872
- 478
- 30
- 448
- 78
Removed the lower cowl next. The two halves normally rest on those two big rubber bushings, 2 on each side of the motor. In the attached picture of the side of the engine they are in the two lower corners. Once the two halve are unscrewed, they just slide off of those bushings.
The two halves are attached with 4 screws that run along the bottom of the two halves. Two pictures are attached showing there placement: two towards the front and two towards the back. The 4 screws seemed a little tricky to find if you didn’t know what you are looking for. Also, you need a long ¼ drive extension and 5/16” socket to get at them properly.
Using my pretty high-powered vacuum to suck what I could out of the #6 (bottom) front half opening, and PB Blasted it as well, but the motor is still locked up.
So now the next step will be to make sure I’ll be able to get the flywheel off.
02-19-2018, 08:42 AM #4
If you don't already have one pick up a lifting eye with the flywheel puller built in. They are inexpensive and will save you a ton of time and grief.
RockTeam Junk
02-19-2018, 07:44 PM #5
5000 RPM
- Oct 2008
- Plainville, CT
- 872
- 478
- 30
- 448
- 78
Very good idea… Years ago I made one before I realized you can buy one. We'll see again how it works.
02-19-2018, 08:01 PM #6
Nothing wrong with home made. Many of my tools are just that.
RockTeam Junk
02-20-2018, 10:14 PM #7
5000 RPM
- Oct 2008
- Plainville, CT
- 872
- 478
- 30
- 448
- 78
02-25-2018, 03:22 PM #8
5000 RPM
- Oct 2008
- Plainville, CT
- 872
- 478
- 30
- 448
- 78
This is what I’d consider excellent and exciting news on this engine.
As I was undressing (i.e. remove fuel pump, oil pump, stator) the powerhead a bit to make it easier for removal and opening it up, my son come over to take a look at the progress. I went to give it a spin to show him how locked up it was… but this time it spun freely. This was amazing.
Best I can determine is that the stator was rusted up, probably rubbing on the magnets. As you can tell from the attached flywheel picture, one of the magnets is broken. Not sure if this happened before I tried to spin it or if I did than when trying to spin it. In any case it spins nicely now with that rusted stator removed.
One thing I am wondering is if I put the starter back on can I get a valid compression test without putting the reeds back on?
02-25-2018, 04:16 PM #9
Probably be fine. Compression don't start till after ex port closes.
RockTeam Junk
03-05-2018, 07:19 PM #10
5000 RPM
- Oct 2008
- Plainville, CT
- 872
- 478
- 30
- 448
- 78
03-08-2018, 09:12 PM #11
5000 RPM
- Oct 2008
- Plainville, CT
- 872
- 478
- 30
- 448
- 78
03-08-2018, 09:19 PM #12
Screaming And Flying!
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
Could be fogger oil or WD or something in high holes. Or maybe all the holes and the low ones are just worn.
03-10-2018, 01:46 AM #13
Pull the heads off.
03-10-2018, 07:13 PM #14
5000 RPM
- Oct 2008
- Plainville, CT
- 872
- 478
- 30
- 448
- 78
Good advice. Looks to me like there may be a small leak due to a bad head gasket. The head (#3cyl - middle in the pic) has small gouges matching up with marks in the block. I'm thinking the head has to be replaced or machined to clean that up. Not sure of the tolerances though. If this is all it is I'm feeling lucky.
03-10-2018, 07:49 PM #15
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
How's the deck look after you peeled the gasket off? Those gouges look like they are in the squish area of chamber.
1994 Mercury 2.5 260 Rebuild
By Rock Steady in forum Technical DiscussionReplies: 19Last Post: 07-30-2022, 06:03 PM -
1994 Mercury Pro Max rigging
By Warrenroadie in forum Technical DiscussionReplies: 32Last Post: 02-17-2017, 04:01 AM -
Mercury Tech: 1994 2.5 200HP Mercury EFI XR
By FL_Sanger_Barefooter in forum Technical DiscussionReplies: 7Last Post: 06-26-2016, 08:20 AM -
Mercury Tech: 1994 Mercury 175 2.5 oil conversion
By Liberator225 in forum Technical DiscussionReplies: 2Last Post: 04-23-2012, 07:10 AM -
Need Some info on 1994 Mercury 200 xri
By cheapbeater in forum Technical DiscussionReplies: 3Last Post: 04-16-2009, 10:20 AM
