				Results 46 to 60 of 241
		Thread: Vector resurrection -
	02-14-2018, 09:54 PM #46
Erik I thought that computer looked familiar, here is the three stock a6 fuel tables. Some more stuff in the background but this is most of what we need. As in I’d be jetting differently that straight 88’s
2023 TUFF 25
	02-14-2018, 10:01 PM #47
						Screaming And Flying!
 - Sep 2001
 - shreveport,la
 - 5,706
 - 118
 - 85
 - 774
Ahhh. 4% in the middle. I was thinking 6%. I see the 9% in the bottom two starts at 8500, not 9000 I was thinking
Erik Kiser
				texasvector liked this post
	02-14-2018, 10:10 PM #48
	02-14-2018, 10:55 PM #49
terds.. I'm switching to carbs anyhow. ....
air ram setup81' HYDROSTREAM VECTOR / slightly Modified 200
				Capt.Insane-o liked this post
	02-14-2018, 11:11 PM #50
						5000 RPM
 - Mar 2015
 - DFW
 - 661
 - 16
 - 42
 - 366
 - 232
	02-14-2018, 11:25 PM #51
I'm carb stupid. . but carbs don't like positive psi so i been told.... never heard of 7 psi on fuel. ..... if i was him. .. id rip that junk ass carb vortex off the front. .. put laser/svs laser on front..... start with a48 on plus side and tune from there. ..... watchIng pistons top
	02-15-2018, 01:07 AM #52
	02-15-2018, 01:31 AM #53
 - Sep 2001
 - shreveport,la
 - 5,706
 - 118
 - 85
 - 774
	02-15-2018, 02:10 AM #54
						5000 RPM
 - Mar 2015
 - DFW
 - 661
 - 16
 - 42
 - 366
 - 232
	02-15-2018, 05:49 AM #55
						5000 RPM
 - Sep 2006
 - 472
 - 166
 - 9
 - 43
 - 51
I know little about this but do have the brucato and found the difference was about 8 points between the top two cylinders and the bottom 2 and the middle at 4 but this was on a lake boat turning about 6800.
What is meant by load on the chart?
	02-15-2018, 07:58 AM #56
 - Feb 2015
 - Ontario
 - 8,124
 - 205
 - 324
 - 1938
 - 2015
	02-15-2018, 08:00 AM #57
aim dash is a blessing for this, amazing how far we have come.
Coffeeguy, load is the the table on the left side. It is really vacuum, the top of the map is zero vacuum he bottom depending on the map if full vacuum.
Merc wasn’t stupid, these base maps are very good. I’ve been playing with them for about 15 years, lots of dyno time and been it lots of box’s Very few times do maps very a lot. Meaning most guys arrive at the same conclusions.2023 TUFF 25
				coffeeguy thanked for this post
	02-15-2018, 08:12 AM #58
 - Sep 2001
 - shreveport,la
 - 5,706
 - 118
 - 85
 - 774
I always come back pretty close to an A6. It really is a very good map. Mercury engineers are wicked smart and this was basically their factory race engine. It is extremely hard to improve on any of it, whether it be in the port work or the fuel map. Take the soft rev limiter out and you're pretty much there other than some minor tweaks where the boats idle in
Erik Kiser
	02-15-2018, 08:18 AM #59
Those offsets are factory merc. Very few of the guys that just play with mapping touch them. Only with lots of dyno time (pressure sensors and exhaust gas analysis) will you be able to eke much more.
Remeber, and this was missed in fongs chest. These motors get help from above, that help requires fuel. All six holes do different amounts of work.2023 TUFF 25
	02-15-2018, 08:22 AM #60
AHHH nice. Same stuff. Here's a screencap I grabbed from the virtual machine inside my Linux PC. It's going to take a bit of work but I think I can use quite a bit of that info in the box I'm working on. Knowing the idle and WOT vacuum is a big piece to getting one started and fired up, although I'm sure as hell not going to guinea pig with a nic motor, especially a drag. LOL.
20' Action Marine restoration/resurrection.
By Hot Shot Merc in forum General Boating DiscussionReplies: 183Last Post: 08-12-2023, 02:11 PM -
Cosworth 275 Resurrection
By promax150 in forum Technical DiscussionReplies: 4Last Post: 07-16-2015, 08:33 AM -
Aquabuff-Rallysport Resurrection
By Checkmate2.5 in forum Detailing and CareReplies: 27Last Post: 03-26-2008, 07:21 AM -
2.4 Resurrection
By Surface Scratcher in forum Technical DiscussionReplies: 1Last Post: 02-25-2008, 07:49 PM
