Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 62
    May 2006
    Edgerton, WI
    this is neat
    Hydrostream Owners Group
  2. Thanks texasvector thanked for this post
  3. #17
    10 Post(s)
    Congrats Dude!!
    Lot of people w/Streams talk **** about #s but it's something else entirely to put one on the board.
    Well done sir.
    Always liked that rig.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  4. Thanks texasvector thanked for this post
  5. #18
    Motor is important, but imo, the bottom is the secret to the higher speeds. Very nice boat, and motor.
  6. Thanks texasvector thanked for this post
  7. #19
    Nov 2005
    MAINE
  8. Thanks texasvector thanked for this post
  9. #20
    Aug 2012
    beaumont, tx
    thanks fellas!!! if anyone knows me ...they know how much time i put into it.....alot of failures. setup has more in it....and motor definitely has more in it (aint pushing it hard cause im sick of scattering em!)
    my goals were a 104/105 pass and consistent 102
    need to dial setup in (think im a 1/4" off in height)
    coned gear case would be faster too
  10. Likes RussF, Instigator, Capt.Insane-o liked this post
  11. #21
    Quote Originally Posted by texasvector View Post
    set new PR for me sat.....had a handful of 101 passes and clicked a 102.25mph late in the day......
    Attachment 396624
    think she might have a few more with a couple of tweeks then im done
    https://www.youtube.com/watch?v=Ux_9BUk_mgQ
  12. Likes texasvector liked this post
  13. #22
    10 Post(s)
    Yep
    When I had mine I got to mid 90's fairly easily, high 90's after a bazillion more trips to the ramp and I think another yr to get that last few mph'.
  14. Likes texasvector liked this post
  15. #23
    Tex ,
    Now ya went and done it .. ( Congrats on a new P.B. )
    Ya got Fong workin over time ..
    He's tellin the lil motor guru how its sposta be done
    Here's some top secret video of him and FMPulse doing some exhaust log stuffin ..
  16. Likes texasvector, BUZZIN' DOZEN liked this post
  17. #24
    coned 200 case is 3 mph faster than a sporty/cle, xr6 case is faster than that..
  18. Likes texasvector liked this post
  19. #25
    Dec 2011
    Ludington michigan,on the shore
    Well done,Very nice job!!!! Stay safe.
  20. #26
    What does the hull do when you hit about 90 going up to 100? Are you trimming down a little? Just curious....
    Aug 2012
    beaumont, tx
    i have a flat pad with an ally pencil roll added. .. about .050"
    i usually have to trim up. .. bumping it all the way till 100
    previously i was running a 28 drag 3..... clicked 100 with it a handful of times. .... the boat ran nose high......i hit 98 all day and had to bump it up twice to get the trips. ... one of those " should i or shouldn't i things" lmao
    last run i swapped to a 30ET and boat flattened out
    see the difference
    with the flattened pad this boat has difficult time lifting the ass.....the lip helps and also helps keep it from kiting (which it used to kite at 90 alot)
    i still need some seat time with the ET and maybe 1 or 2 adjustments in height... (the boat hunts running about 60....i think the gear case is digging then letting go...especially if im overtrimmed=gearcase nose lower)
  22. #28
    Thanks for the fine tuning and driving tips. The pointy nose streams seem to run faster having a little "help" with stern lift. You obviously have it tuned perfect for your balance also. Side steer streams going 100 are fairly rare.
  23. Likes texasvector liked this post
  24. #29
    Aug 2012
    beaumont, tx
    ive ran a drag 4 on this boat before (although it had different mod on pad not roll) and that prop drove and carried the boat well...if you need tail lift thats a badass prop....i was gonna give the ET a fair shot and retort to the drag 4 if needed
    balance is key....cut the end off a dumbell set...glassed it in the wing...so i could stack weights as needed for balance ...think i have 20lbs over there. i can hold boat wide open for miles in a slight left hand bend......no input......going dead straight it takes a lil driving
  25. Likes NICE PAIR, XstreamVking, olboatman liked this post
  26. #30
    Thumbs up
    Running very well!!..... They should never underestimate these little 2.5.....
    OH, that power head looks a bit sloppy.....
  27. Likes texasvector, NICE PAIR liked this post
  1. hydrostream vector
    By jjamieson7284 in forum Hulls up to 20'
    Last Post: 08-30-2015, 08:21 PM
  2. 79' Hydrostream Vector
    By erichuegele in forum General Boating Discussion
    Last Post: 09-03-2013, 04:20 PM
  3. 81 Hydrostream Vector
    By Elvis in forum Fiberglass and Composites Discussion
    Last Post: 08-02-2009, 06:45 PM
  4. hydrostream vector
    By justinn in forum Technical Discussion
    Last Post: 04-26-2007, 03:58 PM
