Page 30 of 50 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 LastLast
Results 436 to 450 of 745
Thread: Merc V6 History
  1. #436
    Quote Originally Posted by W2F a V-King View Post
    I was told by a Mercury rep some 30 years ago it was just what you said. Machine-Freeze- Snap with a cone, found a video that might be what is done today?
    https://www.youtube.com/watch?v=QlVrDJBiqd4
    Cant see that working for a roller as you have the damaged line where the laser cut it.
  2. #437
    Fond du Lac WI
    [QUOTE=powerabout;3012283]Cant see that working for a roller as you have the damaged line where the laser cut it.
    Mercury used, and probably still does, a cracking process using a shallow vee notch on the rod thrust face and small drill holes thru the cap side to side. It has been 40 years since I was in manufacturing and don't remember the correct steps, but the crack did not follow a straight line like that laser video, and went back together with the micro grain lumps and bumbs realigning, then the rod was finish ground and honed - you would not see the crack after those operations. rckid74 hopefully remembers the individual steps better than I do.
  3. Thanks Mark75H thanked for this post
    Likes Mark75H, mrcrsr liked this post
  4. #438
    May 2013
    Pickett, WI
    [QUOTE=bernie;3012296]
    The rod shown in that video is for a 4-stroke engine so would be used with a plain bearing not rollers. If you tried to run rollers over that notch across the bearing surface, you'd have instant failure! I was involved in Mercury's development of the cracked rod but don't remember a lot about it. It's pretty much as you say Bernie. You have to harden all the material in the crack zone, hense the drilled holes to allow the carburizing into the interior of the section and the notches to act as stress risers to start the crack. Not sure if we used a wedge to force the crack or something else.
  5. Likes Mark75H liked this post
  6. #439
    5 Post(s)
    Jerry, one of the first 50 perhaps?
  7. Likes joyrider, Kitch liked this post
  8. #440
    5 Post(s)
  9. Likes joyrider liked this post
  10. #441
    5 Post(s)
  11. Likes joyrider liked this post
  12. #442
    5 Post(s)
  13. Likes joyrider liked this post
  14. #443
    5 Post(s)
  15. Likes Dave Strong, joyrider liked this post
  16. #444
    5 Post(s)
    ...studed heads...
  17. Likes joyrider, Kitch liked this post
  18. #445
    5 Post(s)
  19. Likes joyrider liked this post
  20. #446
    5 Post(s)
  21. Likes joyrider liked this post
  22. #447
    5 Post(s)
  23. Likes joyrider liked this post
  24. #448
    5 Post(s)
  25. Likes joyrider liked this post
  26. #449
    5 Post(s)
  27. Likes joyrider liked this post
  28. #450
    5 Post(s)
  29. Thanks powerabout, rckid74, TroyWoodF1 thanked for this post
    Likes W2F a V-King liked this post
