Results 1 to 15 of 21
    minocqua, wis
    side pin vs top pin
    when did this come about and why .
    Side pins were falling out. Top pin cannot come out but a lot of the experts like side pin so both ring gaps do not line up with each other. Done correctly side pin will not come out.
  3. Thanks outasite thanked for this post
    Likes Dave Strong liked this post
    Aug 2009
    mpls,mn
    I know it happens but just don't get how the pin can get past the ring gap? but it sure does happen.
    Moline,Ill
    Quote Originally Posted by eli View Post
    '95 is about when they switched from Mahle's to wiesco's, if you have, from the factory, 141 rods then wiesco, if 5250 Mahle.
    I've never heard of a Mahle losing a pin!
    is gone
    Aug 2009
    mpls,mn
    Thought it was the factory 2.4 Bridgeport that started to loose the pins first?
    Moline,Ill
    I never heard of a problem till they switched to wiesco's. the top pin 280 wiescos came out in 03'-04'?
    is gone
    minocqua, wis
    reason is i have a set of side pin mahle's i bought from jay smith racing and being low hour and fine condition was thinking of using them without having top pin till next go around ring job.
  9. #8
    Moline,Ill
    I wouldn't have a problem running the "real" Mahles, but not the pro marine junkers!
    is gone
  10. Likes JPEROG liked this post
    Dec 2001
    1949 mercs were top pinned. Maybe 1954 they went side pin so the gaps didn't line up. No problem ever with merc rings turning till V6 big bore motors. Because the exhaust port is big and has no bridges. Every time the ring goes past that big hole it beats the locating ring. Bigger hp bigger hole. The shape also makes things happen differently. A nice shape will ease the ring back better. The pin on some pistons are fully covered by the ring....most 2.0/2.4s. Those are bigger pins than the ones on 2.5 motors that are half covered by ring. Most stock pistons will live till you bear/rev too much.Wiscos grow more and the pins fail. The males have trick wrist pin locks..... try to get them.
    Moline,Ill
    Ain't buyin' it, never had a problem with the Austrian made Mahles, throw the wiesco's in and BOOM!
    is gone
    Detonation is the biggest culprit. Out of all the 2.4s and 2.5s that I have run, I had one pin rattle out. It made a mess but I shouldn't have been running old fuel and knew better.
    Aug 2009
    mpls,mn
    Thing was how does the pin get out past the ring gap? heat?
  15. #13
    minocqua, wis
    Think it keeps wearing gene trichel from Oshkosh showed me many years ago how to properly stake pins in 86 200 so they don't move outward
  16. #14
    minocqua, wis
    Think i,m going to lighten these and run them
  17. #15
    Dec 2001
    I think males are good.....don't know where ya going to lite em. 6000 rpm....100 per sexond.....things are happening fast. Turn up the speed....Ring flutter.
  1. Converting Action 18' side x side to center steer?
    By Upstaterpaul in forum Props, Setup, and Rigging
    Last Post: 09-08-2014, 05:15 PM
  2. Slight side to side movement at flywheel
    By racer7x in forum Technical Discussion
    Last Post: 10-15-2013, 03:15 PM
  3. Replies: 2
    Last Post: 07-13-2011, 01:28 PM
  4. Twin 2 litre Mercs side by side on a T4 Housing
    By MagicFloat in forum Outboard and Racing History
    Last Post: 01-08-2003, 07:48 PM
