Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
    How is the over hub for getting on plane vs the thru hub?
  2. #17
    Feb 2010
    wisconsin
    Thru hub will plane better 9 times outa ten... It essentially gives you a longer planing surface.. Just like using a bigger wider longer slalom ski... Easier to plane out
  3. Likes AZMIDLYF liked this post
  4. #18
    I'm experimenting with thru hubs for the extended housing lift because of the extra weight of the 3.2's over the 2.5's
    I'm trying 5 blades for the better slip numbers.
    My vented Bravo 32's stall for about 5 seconds and then snap loose, the rpms go 5000ish and the boat leaves hard.
    The 5 blade long hubs I tried were not vented and the stall time was way longer, they didn't break loose till almost on a plane.
    Venting them should cure that but they are borrowed props.
    I was looking for some transom lift not the amount I got.
    The only over hubs I own are an old set of 34 humpbacks, they break loose early, smoothly, and carry the boat well.
    I have not tried any late model over hubs.
  5. #19
ID:	395716Click image for larger version.
ID:	395715Click image for larger version.
ID:	395717Click image for larger version.
    I have a pair of 32 4 blade thru hub herings that you are welcome to try. I have never run them "I bought them to use when the boat is over loaded (4 people on board)". I also have a set of 34 Dewalds that I will be using on my skater. Both sets are yours to try if you wish. The only thing that I ask is that if they are damaged then they are replaced. Dan has some 5 blade stuff that is working well on the DW28 and there is a set of top secret props that he is still waiting on.
  6. Likes AZMIDLYF liked this post
  7. #20
    Quote Originally Posted by JPEROG View Post
    Thank-you Joe, I appreciate the offer. I've been talking with Dan and I think my next test might be the Herrings he has.
    32's are probably the right pitch as I do tend to run with a boatload of peeps and more fuel than SkinnyDale. :-)
  1. Hydraulic steering question: " Using a close 7" Cylinder" | F1 or Mod Vp Guys?
    By Pachanga_rick in forum General Boating Discussion
    Last Post: 06-13-2016, 11:40 AM
  2. Replies: 0
    Last Post: 08-30-2015, 10:32 PM
  3. Replies: 32
    Last Post: 06-02-2013, 11:34 PM
  4. 11" "HOSS" type cut prop info
    By glastornjet73 in forum Props, Setup, and Rigging
    Last Post: 07-13-2010, 08:50 PM
  5. Prop "cuts" - Southern Guys ?
    By MattGreen in forum Technical Discussion
    Last Post: 09-28-2003, 04:37 PM
