Page 1 of 7 1 2 3 4 5 6 7 LastLast
Results 1 to 15 of 97
    Oct 2015
    Kentucky lake
    Ingredients to make killer 2.0
    Can someone school me on whats inside a F1 powerboat merc 2.0 powerhead , or maybe HP numbers at 9-11,000 rpm I want to learn as much as i can, block base 2.4 or 2.5, front half,porting numbers , compression ,lossing bottom end doesn't matter to me..
    Someone put up the SST120 specs a while back, maybe they will repost as a start.
    They are a bridgeport block, kind of their own special thing. The one I ran on my Viper came with sheet stating 312 hp at 9200. It had 180 psi. I put a spacer, pcu and cut the heads to 18cc, stock they were 21 cc.
    They don't pull as hard as 2.5 but they are a wicked little motor. I run mine at 20:1 with r50 or royal purple and 110 octane. It was tough on reeds until i switched to the coated sport jet blocks. I acquired two more this year and am up to five of them now. Just need a few doo dads to complete the last three.
  4. Thanks 30velocity, Keaten thanked for this post
    Likes Michael J Giesler, wing nut liked this post
    That's a wild motor
    Oct 2015
    Kentucky lake
    Cool finally some numbers..thanks ok can guy make 250 hp with a fishn mota 2.4 based 2.0 if so wat rpm area does it need to ported for
    Feb 2007
    lily lake WI
    The only problem is no one is making pistons for them good motors on lite boats
  8. Thanks Streamin-in-a-Virage thanked for this post
    Likes specboatops liked this post
    Dunno why you would want to go through all that. The 2.0 f1 is a full out race motor, They need a lot of compression, high octane fuel, really good oil, lots of rpm to run. If you have a 2.4 block have James Perry put steel mod vp sleeves in it with some tubes and the other neat little stuff he does. Set it up to run on 135-140 psi. It would take a lot of work to try and make a fishing block 2 liter make an honest 250 hp.
    Oct 2015
    Kentucky lake
    Ok thats good info im still learning about wats not worth it, and wats realistic thanks ,
    Quote Originally Posted by Michael J Giesler View Post
    If you sent Wiseco a piston they could make you a dozen?
    Sure , just as long as you pay for the other twenty four that it takes to fill a minimum custom order ...
  13. Likes Michael J Giesler, StratosVT liked this post
  14. #11
    Last I asked not too long ago 12, maybe it's a different situation with these but I'm not sure why?
    Askin and writing a check jogs two different memory sensors ...
  16. Likes Capt.Insane-o liked this post
    100% , dozen was the word. No cheque strictly cash.
    Actually I had bought 14 and then asked later to find I could have done a custom. If it's a totally new piston then maybe it's different.
  18. #14
    Moline,Ill
    This is going back at least 15 years, but a friend of mine was turning 800cc arctic cat triples into 1108's and he had to order 50 pistons!
    is gone
  19. #15
    Oct 2015
    Kentucky lake
    Would it be smarter to replace the 2.0 sleeves with 2.4 sleeves after booring and change pistions to 2.4 of course would that be automatic +25 -50 hp ? ill be porting anyways and running 5or7 petal front with wh20 carbs
  1. Wtb non Rachel ingredients 1:87 reverse gear
    By pappa pete in forum Lower Units
    Last Post: 03-24-2017, 01:09 PM
  2. killer killer photo.........surfaced speedmaster....trick
    By PARKER RABE in forum General Boating Discussion
    Last Post: 02-05-2011, 08:14 AM
  3. Sorry dog killer..................
    By skydog in forum The Scream And Fly Lounge
    Last Post: 11-30-2010, 01:22 PM
  4. Time to make your keyboard make a differance!
    By The Big Al in forum The Scream And Fly Lounge
    Last Post: 04-08-2006, 02:12 PM
