Results 1 to 10 of 10
    Apr 2016
    Victoria bc canada
    GPS receiver/puck location on STV
    Hey guys, Just bought a new gaffrig carbon fibre monster GPS Speedo, it's going to be mounted on my euro. I've seen a lot of people mount the receiver on the dash... Can it go anywhere else? There's no info in the install instructions on mounting location... curious if people have mounted them elsewhere with still maintaining an accurate reading, thanks!
    15.5 cobra 175 hp merc - sold
    18 tahiti tiger O/B 200 hp merc - sold
    19 STV euro - 2.5 merc DRAG
    Seebold F1 tunnel - 2.0 F1/champ
    Mine is glued under my deck and works fine. Use some tape and put it under there and check out what kinda signal you get. Beats having it on top of deck.JMO
    Cape Coral fl
    I have mounted dozens under the dash or deck never a problem
  4. Likes NICE PAIR, tux974, Frank Molé liked this post
    Apr 2016
    Victoria bc canada
    Ok great, where abouts under the dash? Screw it down to the forward bulkhead? Does it need to be facing up? Thanks again!
    facing up (horizontal to deck) If you have a bracket like this and dont mind drilling a couple holes or just put some silicone adhesive on the dome and stick to the underside of deck
  7. Likes lightspeed, tux974 liked this post
    Apr 2016
    Victoria bc canada
    Ok great, Thanks for the advice!
    If you going under and can not find the bracket I use a small thin aluminum strip, bend accordingly to support it. Bracket is a good idea especially in a HPerf hangin and banging application.
    Apr 2016
    Victoria bc canada
    Quote Originally Posted by tux974 View Post
    Exactly what I was thinking, bend up an aluminum L bracket, screw it to the forward and mount it so the top of the receiver is about an inch from the bottom side of the top deck.
    Mine has been glued since I put it there. I dont like putting any more holes than necessary above or below deck but I only run flat water
    Jul 2002
    Las Vegas, NV
    Built this bracket back in 2003. Been there ever since. One is an external GPS antenna for my GPS, the other is for the GPS speedo.
    Keith-
  1. WTB LOWRANCE LGC-2000 GPS puck
    By CircleHook in forum Parts Wanted
    Last Post: 03-08-2017, 07:00 AM
  2. livorsi gps puck lifespan
    By aggiestckl in forum Technical Discussion
    Last Post: 03-31-2015, 06:23 PM
  3. GPS Speedometer Receiver Location Recomendation
    By Pickinator in forum Electronics, Audio Systems, and Wiring
    Last Post: 09-04-2014, 10:02 PM
  4. Gaffrig GPS Antenna/Receiver location??
    By PORT in forum Technical Discussion
    Last Post: 04-06-2007, 02:56 PM
  5. Gps Wiring & "puck"/head Location Questions...
    By VELOCITOY in forum Technical Discussion
    Last Post: 05-19-2003, 10:27 AM
