Page 2 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 16 to 30 of 247
    12 Post(s)
    Interesting
    Ive thought for yrs that was the answer.
    Done right it'd be stronger than the OEM casting.
    So you'd be away from Merc controlling rules on our powerheads and mids.
    I read somewhere that Ron Hill suggested casting a speed master housing from stainless.
    Do that w/some improvements and you'd now have an APBA legal motor w-no political manipulation from any engine mfgs and run any powerhead you desired ��
    Yes , absolutely .
    The " setback spine " above was built like that . Todd wanted to be able to use the three ram trim and a true 15" can for the bass boat guys . I built 5 or 6 for him and 1 went to Key largo .
    We often talked about doing a Monocoque can , but never really took it any farther than napkin drawings ..
    Top flange , bottom flange , some mounting bosses , some star wars-y looking corrugation on your outside panels and the same for some "baffles" inside and you would have a light weight bad azz can for not a lot of money ...
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  2. Likes noli liked this post
  3. #17
    anyone ever play with NMAE2000 or CAN bus protocols?
  4. #18
    Nov 2009
    long island NY
    Quote Originally Posted by noli View Post
    Wiki-pedia defines an Engineer as...
    people who invent, design, analyse, build and test machines, systems, structures and materials to fulfill objectives and requirements while considering the limitations imposed by practicality, regulation, safety, and cost
    A collection of Chaz's most significant works.
    Please share your pics here.
    "a bracket that split in the front on one side and the top on the other . We , notched , welded ,wrapped , side plated and then bored the tilt hole , pressed in a 6061 tube and then pilot reamed it to final size ... "
    Attachment 392591
    Attachment 392593
    I believe this is my saddle bracket. I race with it offshore and its so much stronger than stock. I have no worries about going out in the rough stuff and making it back in all intact.
    Chaz is the man and very talented and a great easy guy to work with.
  5. Likes noli, AZMIDLYF liked this post
  6. #19
  7. Likes noli, Capt.Insane-o, NICE PAIR, phillnjack liked this post
  8. #20
  9. #21
    Quote Originally Posted by davemvegas View Post
    I sent you 2 Burger King coupons. I will take 2 of the cheap custom mids. Thanks.
    Throw in a large boiled peanuts from Lil Jim Bridge Bait ~n~ Tackle shop , and ya gotz yourself a deal ...
    Chaz = thinkin , if Davie or I tried drivin one of them little crouch down on yur belly racers , that's how they'd find us after the buzzards picked us clean ..
  10. Likes davemvegas liked this post
  11. #22
    Yes sir Mercracer that's you swivel bracket ...
    The late model plenum with early hardware was an attempt at building an inexpensive alternative to buying a 300x reed adapter plate .
    My original idea was to drill and tap the plastic (phenolic) block to bolt the reed blocks to . I chickened out , thinking that the threads might melt , so instead I sandwiched a opti reed plate on the far side because it was radiused pretty good and had the factory threads . I did move each pair of injectors closer to each other and made my own fuel rail and tabbed and spacer mounted it to the opti plate . Worked well , I just didn't like the idea of the injector close to the corner of the port . I built a couple then moved onto the 2 1/2" thick aluminum slabs ...
  12. Likes noli liked this post
  13. #23
    cutting bracket hydraulic ram down so that it fits on 15" mid-cans
  14. Likes AZMIDLYF, Instigator liked this post
  15. #24
    The Slop-Stop...
  16. Likes noli liked this post
  17. #25
    "They made me an offer I couldn't refuse . A credit for canole' at Georgio's ... "
  18. Likes vnemous liked this post
  19. #26
    "We have been whittling on a couple of slabs of aluminum, that will move the injectors outside like a X motor. Along with a few other subtle improvements over the production piece ..
    I have another setup that we are ready to test and do any final tweeks that might come up, that will be a bunch cheaper than buying all the parts from Merc to do an outside injector conversion on a 3.0L which will fit under any year cowling .. "
  20. Likes davemvegas, W2F a V-King, NICE PAIR liked this post
  21. #27
  22. Likes noli, W2F a V-King liked this post
  23. #28
  24. Likes noli liked this post
  25. #29
  26. Likes noli liked this post
  27. #30
  1. Trust me I'm an Engineer (funny pics)
    By Stitch King in forum The Scream And Fly Lounge
    Last Post: 11-14-2012, 08:13 PM
  2. New show. American Inventor
    By WILDMAN in forum The Scream And Fly Lounge
    Last Post: 03-16-2006, 07:49 PM
  3. AutoCad and Inventor
    By Fibertron in forum The Scream And Fly Lounge
    Last Post: 11-30-2004, 09:05 AM
  4. Anyone know the designer of
    By Dukeofchippewa in forum Outboard and Racing History
    Last Post: 10-03-2004, 11:43 AM
