Results 16 to 30 of 247
11-25-2017, 07:09 PM #16
Interesting
Ive thought for yrs that was the answer.
Done right it'd be stronger than the OEM casting.
So you'd be away from Merc controlling rules on our powerheads and mids.
I read somewhere that Ron Hill suggested casting a speed master housing from stainless.
Do that w/some improvements and you'd now have an APBA legal motor w-no political manipulation from any engine mfgs and run any powerhead you desired
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
noli liked this post
11-25-2017, 07:42 PM #17
anyone ever play with NMAE2000 or CAN bus protocols?
11-25-2017, 09:13 PM #18
11-25-2017, 09:20 PM #19
11-25-2017, 09:21 PM #20
11-25-2017, 10:54 PM #21
davemvegas liked this post
11-25-2017, 11:23 PM #22
Yes sir Mercracer that's you swivel bracket ...
The late model plenum with early hardware was an attempt at building an inexpensive alternative to buying a 300x reed adapter plate .
My original idea was to drill and tap the plastic (phenolic) block to bolt the reed blocks to . I chickened out , thinking that the threads might melt , so instead I sandwiched a opti reed plate on the far side because it was radiused pretty good and had the factory threads . I did move each pair of injectors closer to each other and made my own fuel rail and tabbed and spacer mounted it to the opti plate . Worked well , I just didn't like the idea of the injector close to the corner of the port . I built a couple then moved onto the 2 1/2" thick aluminum slabs ...
11-27-2017, 07:46 PM #23
12-01-2017, 11:53 AM #24
12-02-2017, 07:44 PM #25
vnemous liked this post
12-02-2017, 08:21 PM #26
"We have been whittling on a couple of slabs of aluminum, that will move the injectors outside like a X motor. Along with a few other subtle improvements over the production piece ..
I have another setup that we are ready to test and do any final tweeks that might come up, that will be a bunch cheaper than buying all the parts from Merc to do an outside injector conversion on a 3.0L which will fit under any year cowling ..
12-04-2017, 12:04 AM #27
12-04-2017, 12:08 AM #28
12-04-2017, 12:09 AM #29
12-04-2017, 12:10 AM #30
Trust me I'm an Engineer (funny pics)
By Stitch King in forum The Scream And Fly LoungeReplies: 3Last Post: 11-14-2012, 08:13 PM -
New show. American Inventor
By WILDMAN in forum The Scream And Fly LoungeReplies: 0Last Post: 03-16-2006, 07:49 PM -
AutoCad and Inventor
By Fibertron in forum The Scream And Fly LoungeReplies: 31Last Post: 11-30-2004, 09:05 AM -
Anyone know the designer of
By Dukeofchippewa in forum Outboard and Racing HistoryReplies: 0Last Post: 10-03-2004, 11:43 AM
