Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 16 to 30 of 89
Thread: AV - Gas?
    Lindenhurst, NY
    I winterize with it from a small tank and leave the tanks in the boat empty so the ethanol doesn't attract water over the winter.
  2. Likes ghost28 liked this post
  3. #17
    Dry tanks, can't leave the 10% sitting around. Carbs and pumps and lines empty. Good idea with the 100 LL if you run it through and fog behind.
  4. Likes 89LASER, ghost28 liked this post
  5. #18
    Richland, WA along the Columbia River
    I run 100LL, either straight up or mixed 50/50 with premium pump gas. The AV gas is oxygenated (I could be wrong) or engineered to run at higher altitudes, so I always run Lucas Fuel Injector cleaner/lubricant.
    If I remember correctly AV fuel used to be the base component used in race fuel, the manufacturer would then add hydrocarbons like TEL.
  6. #19
    Jan 2010
    Venice, FL
    You boys need to move South ...
    And fwiw less'n yer motor really needs it, octane ain't all it's cracked up to be. I've gotten by with 87 in a pinch ...
  7. #20
    Jun 2012
    Bainbridge, Ga
    I buy my 112 from local Sunoco station that has 100 also
    Flint River Mafia
    1983 Laser LTV #007 RIP Lloyd Burns
    1994 Mirage RR "The Purple Drip" SOLD
    2002 Laser LTV "SOLD"
  8. Likes 2.5-21 liked this post
  9. #21
    Dec 2011
    united states
    Is straight 91 or better difficult to find in that area?
    No, not really. A lot of gas stations and shops carry Sunoco race fuels and up in northern NY 91 non ethanol is at every Stewart's shop.
  10. #22
    May 2001
    great south bay
    Quote Originally Posted by Coryc View Post
    The Liberals here in this part of new york dont feel we need non ethanol fuel.....
  11. Likes Bodhi liked this post
  12. #23
    What motor are you fueling? Sunoco 94 is about the best pump here. Goes by the brand PetroCan, and is 10% alc. Works great with good oil.
  13. #24
    Dec 2011
    united states
    Quote Originally Posted by 2.5-21 View Post
    yeah I hear ya. I live in NY just over the border from danbury CT and I gotta drive an hour to get the 91 non ethanol. Fortunately my whole family lives in lake George so I'm up there with my boat quite a bit and fill it up with the non ethanol.
  14. Likes 2.5-21 liked this post
  15. #25
    Sep 2004
    northen CA
    Ran a lot of 100LL threw my 2.5 merc s 3000 185lb. fuel matters.
    JJ
  16. #26
    Finland
    Just saying, don't have to follow. On crossflows I have that are fresh rebuilds with all things right and blow-by that's minimal and cranking psi done correctly at 170psi. I run min 91 to 94, never an issue with even lots of ign. I run forged pistons and lots of good oil. Same motors still with 170 psi and 200hrs, no issues pistons look beautiful. Doesn't mean it works for you .
    I run mine omc70 with ~175psi & 21* max timing on our 98e5 here in Finland. Piston tops & plugs look just fine and 4% fullsynt oil.
  17. Likes FMP liked this post
  18. #27
    I think it's the limit. But just read on another thread about 190-200psi tohatso 25/30hp stock psi. Not taking consideration of running psi but that's tight for pump gas. Two stroke rotax as well I think are over 200?
  19. #28
    Sep 2009
    Lake One
    Not so here in WNY...1.5mi away.
    Handy site
    Bob
    "have you met my little fly named scream?"
    GSE #1 2004 GSE, 2004 225X Promax... RIP
    GSE #2 2013, Gen2 200XS ROS
  20. #29
    May 2001
    great south bay
    Quote Originally Posted by H20WKD View Post
    Handy site
    Bob
    Great site, A few stations pop up here on the Island once in a while but usually dont stay around long, Maybe we need to promote the ones that do.
  21. #30
    Aug 2009
    mpls,mn
    im told av gas now adays is not what you concider race gas????
  22. Likes obession liked this post
