Results 16 to 30 of 159
Thread: 85hp V4 Mod begins
11-11-2017, 07:31 PM #16'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
11-11-2017, 07:50 PM #17
Screaming And Flying!
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
Phew,lol
11-11-2017, 09:25 PM #18
Actually I was being serious. All has to do with bores and diameters I reckon. Think .004 is tight as they recommend for a oversize piston?
11-11-2017, 10:21 PM #19
I'd bolt the heads back on and go fishing.
71V153 liked this post
11-11-2017, 10:44 PM #20
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
This is the motor that's getting worked to 140
11-11-2017, 10:53 PM #21
....and you can't measure clearances with a feeler gauge, besides ring gap.
11-11-2017, 11:33 PM #22
And for sure not measured at the crown of the piston.
11-12-2017, 07:19 AM #23
Once the ports are brought to 140 specs you need to be right on with piston clearence and ring gap......as they grab rings when sloppy....been there!
JMO (just my Observation)
Gary"12" Super Lite Tunnel (11') "88" 25 Yammy twin carb "BANANA SPLIT"
spybot liked this post
11-12-2017, 07:57 AM #24
11-12-2017, 09:41 AM #25
Pistons are shaped with a taper with top being much smaller than bottom. So it will show much more clearance at top than bottom in skirt area. Just wanted to clarify my post so my short answer didn't appear to be critical or sound like a jerk.
After I read it, saw it could have been taken the wrong way. So measuring at top of piston doesn't really tell ya much, piston would need to be removed and measured near bottom to get an accurate clearance reading.
11-12-2017, 10:50 AM #26
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
Good point, note the extra top clearance is to soak the heat. Measure forged vs cast and note the difference. Marks in the bore will be gone when you bore it.
11-12-2017, 01:11 PM #27
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
11-12-2017, 07:48 PM #28
11-12-2017, 08:07 PM #29
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
I thought to ask, I have an idea but more importantly the build here would probably need to know.
11-13-2017, 02:18 AM #30
- Dec 2001
- 9,501
- 271
- 191
- 1979
Poor mans way. Put piston in bore crown first and check top of bore to bottom of piston with feeler gage.
AE-21 Rigging begins!
By JUPITER PULSARE in forum Props, Setup, and RiggingReplies: 162Last Post: 09-05-2011, 05:27 PM -
The fun begins!!
By ShorePounder in forum Other MotorsportsReplies: 2Last Post: 10-06-2006, 12:00 PM -
The Fun Begins
By Liqui-Fly in forum Fiberglass and Composites DiscussionReplies: 81Last Post: 06-25-2003, 02:38 PM -
Woo hoo, now the fun begins!!
By insptech in forum General Boating DiscussionReplies: 6Last Post: 09-06-2002, 05:04 PM
