Results 1 to 7 of 7
    jonesville, La
    Fuel pump after VST delete
    Do you just us the original pump and mount in boat? How did you mount it, or aftermarket pump?
    Aug 2012
    beaumont, tx
    missed your call buddy
    get ya a Bosch pump....984 or 044
    mount in boat with filter before pump and filter before fuel rail
    I used 1/2" line before pump....3/8" after
    Dec 2011
    Ottawa
    What regulator you use ? Merc gold ? Or does pmax injectors use less than 39psi ?
    Aug 2012
    beaumont, tx
    39 will be fine
    jonesville, La
    Couldn't you just use the promax pump and regulator
    TX......somewhere?
    pro max is a submersible type pump.. probably won't run long "exposed" .. unless its tha early efi stuff which is probably wore out already.
  7. Likes W2F a V-King liked this post
    I'm running out of fuel in the rail on a good long run with my Promax. It's still stock Vst but the high pressure pump is NOT in the vst tank. It sits in front of it. I'm thinking of getting rid of the tank and diagram pump and mounting a small lift pump in the boat to feed the high pump.
  1. WTB: Fuel pump to delete VRO
    By gotboostedvr6 in forum Parts Wanted
    Last Post: 05-26-2016, 06:50 AM
  2. external oil pump delete help merc 2 stroke
    By CauZey in forum Technical Discussion
    Last Post: 04-04-2012, 07:16 PM
  3. Quick weekend fix for oil pump delete! Help!
    By EagleSST in forum Technical Discussion
    Last Post: 06-28-2009, 05:35 AM
