Page 72 of 899 FirstFirst ... 22 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 122 172 572 ... LastLast
Results 1,066 to 1,080 of 13484
  1. #1066
    Apr 2006
    Spring City, TN
    Lars, This should be right up your alley! A factory CCC (going on Mark Rotharmel's #11 Molinari) beside a hopped up later 90 degree Loop Charged motor. Both sporting 6-pac CCC carbs. The Looper has a Dave Bush sleeve and piston kit installed, Wayne Taylor X-Front, and complete Yamaha ignition. The HP/Torque numbers are staggering! Check out this Dave Bush video of a similar build, but with FI.
ID:	390728 Click image for larger version.
ID:	390729 Click image for larger version.
  2. Thanks lars strom, powerabout thanked for this post
    Likes lars strom, FMP liked this post
  3. #1067
    Feb 2008
    Very nice. Thank you RogerH..:thumbsup:
    Attached Thumbnails Attached Thumbnails LooperCrossflow-100.jpg   LooperCrossflowBack-200.jpg   LooperCrossflow-300.jpg
  4. Likes olboatman, Capt.Insane-o, powerabout liked this post
  5. #1068
    GREAT I candy!!!!!! and neat stuff too.
    Gary
  6. Thanks lars strom thanked for this post
    Likes lars strom liked this post
  7. #1069
    interesting cooling mods on the looper.
  8. #1070
    Yup. Looks like some air bleeding addressed with the high connections.
    Gary
  9. #1071
    South Florida
    Never saw a Molinari E boat either.
  10. #1072
    Jun 2009
    Georgia
    44 Post(s)
    It appears the stock motor is a cross.
  11. #1073
    Feb 2008
    The powerhead with the text V6 on the exhaust manifold is the stock looper block.
  12. #1074
    Jun 2009
    Georgia
    44 Post(s)
    Quote Originally Posted by lars strom View Post
    It's the other one Lars. Look at the transfer covers.
  13. #1075
    Jun 2009
    Georgia
    44 Post(s)
    It's the other one Lars. Look at the transfer covers ; it ain't a looper. And the other one looks completely modified,; ignition, flywheel , heads, water plumbing etc.
  14. #1076
    Feb 2008
    The other one is a CCC/RS 2.6 cross-flow.
  15. #1077
    12 Post(s)
    That is correct Lars. You can also tell it's late model ( as in, late '90's and up) w/the step on the top of the back of the exhaust housing.
    I think the F-1 V-8 is also the only looper w/the cross flow style heads w/water jacket covers on them.
    Compare to heads on the fish block.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  16. #1078
    Feb 2008
    On more picture of the two powerheads.
    The closer one is the CCC/RS 2.448/2.6 liter cross-flow introduced 1976 as a 2.448 liter cross-flow
  17. #1079
    Apr 2006
    Spring City, TN
    To be absolutely correct the Crossflow is a genuine 2.4 CCC, but we couldn't find the correct crankshaft. It has a NOS standard 200/235 odd fire crank. The CCC driveshaft will be splined and two stub shafts made. One will be standard CCC length and the other will be 1.1" longer to engage the stock 200/235 crankshaft completely. (because it doesn't have the lower balancer)
    The Looper is a '07 block with a Dave Bush sleeve and piston kit installed, bringing it to 3.3L. The wayne Taylor X-front with CCC carbs is apparent. The complete ignition is Yamaha. This is very similar to the motor in the video (above), but has carbs vs FI. BTW, it weighs 220#s.
  18. Thanks lars strom thanked for this post
    Likes AZMIDLYF, lars strom liked this post
  19. #1080
    what does a CCC P/H weigh?
  1. Evinrude & Johnson Racing 1967+
    By Mark75H in forum Outboard and Racing History
    Last Post: 04-24-2023, 09:58 PM
  2. V8 Johnson/evinrude Outboards
    By baassoc in forum General Boating Discussion
    Last Post: 04-17-2020, 06:21 AM
  3. D and E Class OMC outboards, Johnson 60 and Evinrude 75
    By smokin'joe in forum Outboard Engines
    Last Post: 05-21-2017, 09:24 AM
  4. Replies: 0
    Last Post: 10-02-2014, 09:07 PM
