Page 10 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 136 to 150 of 242
  1. #136
    Quote Originally Posted by mrcrsr View Post
    Attachment 385023. Here's a t2x exhaust chest, u can see how the top 3 and bottom 3 are split.
    what is the firing order on one of those?
  2. #137
    May 2014
    Livingston, Louisiana
    I still have a problem with those 2 also especially 6. It's port actually ends in the exit. If any stuffing takes place it has to happen before pulse reaches tuner due to the low pressure wave pulling it out.
  3. #138
    Jun 2004
    port st. lucie, fl
    I believe it's 162435, which doesn't make alot of sense as the bottom cylinders sequence is backwards, maybe Sam will chime in.
  4. Thanks powerabout, Mark75H, FMP thanked for this post
    Likes Mark75H liked this post
  5. #139
    May 2014
    ok thats solved how about why 5&6 are different?
    My guess is the scavanging is greater on 5 and 6 due to fact how close they are to the tuner, causing it to pull too much of the fuel charge out
  6. #140
    maybe after all this we will learn how an OMC v4 works
  7. #141
    So 1 2 3 are 120* separate pin angle as are 4 5 6. Pairing occurs within each chest. However the scavenging effect because of the long run may influence on others because of 60* pin.
  8. #142
    May 2014
    Just a thought, how about it just as simple as at the end of the exh. event as the flow lowers the last bit of fuel charge that is expelled is stored in the "pocket" at end of port and when the pressure in the cylinder lowers to less than the exhaust back pressure in chest its pushed back in. Just a thought.
  9. #143
    Cylinder is on compression stroke with port open
  10. Likes Mark75H liked this post
  11. #144
    The bottom sequence is reversed for vibration reduction. These run much smoother with a more mellow sound than a regular inline Merc. 123 over 123 must have had a really bad vibration at some speed.
  12. Likes mrcrsr liked this post
  13. #145
    May 2016
    keys
    Am I the only one whose read this thread and now can't stop thinking about getting CRT to cut a block with seperate runners, ready for manifolds to bolt 6 expansion Chambers to? 800hp with a magical musical sound!
  14. #146
    Quote Originally Posted by Whaaaaat View Post
    I love the sound of pipes.....BUT most don't as we found out when we tested the drag sled on the lake yrs ago....and that was with their windows closed!!!! Would like to see them run in the open drag classes though!
    Gary
  15. #147
    Moline,Ill
    is gone
  16. Likes FMP liked this post
  17. #148
    May 2016
    keys
    Yes, that. Now in a billet block designed for it. With CPU controlled water injection to broaden the power band.
    I've seen pictures around, any info on what power they got out of it? How long they got it to last? What rpm they tuned in for?
  18. Thanks Mark75H thanked for this post
  19. #149
    Quote Originally Posted by Mark75H View Post
    Somewhere someone has video footage showing one of those l6 cranks spinning with a strobe light timed to show deflection . It's wild how it bends.
  20. #150
    Shape of ex port, square, oval football Canadian size, bridges and the area just outside the sleeve for expelling and funneling pulse in and out. If bridged, middle ports higher than outer can all effect quality of pulse.
