Results 136 to 150 of 242
08-27-2017, 08:21 AM #136
Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 8,862
- 1084
- 424
- 4811
- 2214
- 9 Post(s)
08-27-2017, 08:25 AM #137
I still have a problem with those 2 also especially 6. It's port actually ends in the exit. If any stuffing takes place it has to happen before pulse reaches tuner due to the low pressure wave pulling it out.
08-27-2017, 08:26 AM #138
I believe it's 162435, which doesn't make alot of sense as the bottom cylinders sequence is backwards, maybe Sam will chime in.
Mark75H liked this post
08-27-2017, 08:38 AM #139
08-27-2017, 08:39 AM #140
- Jun 2007
- 8,862
- 1084
- 424
- 4811
- 2214
- 9 Post(s)
maybe after all this we will learn how an OMC v4 works
08-27-2017, 08:55 AM #141
- Feb 2015
- Ontario
- 8,026
- 205
- 324
- 1938
- 2015
So 1 2 3 are 120* separate pin angle as are 4 5 6. Pairing occurs within each chest. However the scavenging effect because of the long run may influence on others because of 60* pin.
08-27-2017, 09:00 AM #142
Just a thought, how about it just as simple as at the end of the exh. event as the flow lowers the last bit of fuel charge that is expelled is stored in the "pocket" at end of port and when the pressure in the cylinder lowers to less than the exhaust back pressure in chest its pushed back in. Just a thought.
08-27-2017, 09:07 AM #143
- Feb 2015
- Ontario
- 8,026
- 205
- 324
- 1938
- 2015
Cylinder is on compression stroke with port open
08-27-2017, 10:00 AM #144
mrcrsr liked this post
08-27-2017, 10:21 AM #145
5000 RPM
- May 2016
- keys
- 794
- 31
- 45
- 254
- 424
Am I the only one whose read this thread and now can't stop thinking about getting CRT to cut a block with seperate runners, ready for manifolds to bolt 6 expansion Chambers to? 800hp with a magical musical sound!
08-27-2017, 10:34 AM #146
08-27-2017, 11:00 AM #147
is gone
FMP liked this post
08-27-2017, 11:11 AM #148
5000 RPM
- May 2016
- keys
- 794
- 31
- 45
- 254
- 424
Yes, that. Now in a billet block designed for it. With CPU controlled water injection to broaden the power band.
I've seen pictures around, any info on what power they got out of it? How long they got it to last? What rpm they tuned in for?Last edited by Whaaaaat; 08-27-2017 at 11:15 AM. Reason: Grammar
08-27-2017, 11:44 AM #149
- Feb 2015
- Ontario
- 8,026
- 205
- 324
- 1938
- 2015
08-27-2017, 12:19 PM #150
- Feb 2015
- Ontario
- 8,026
- 205
- 324
- 1938
- 2015
Shape of ex port, square, oval football Canadian size, bridges and the area just outside the sleeve for expelling and funneling pulse in and out. If bridged, middle ports higher than outer can all effect quality of pulse.
.....BUT most don't as we found out when we tested the drag sled on the lake yrs ago
....and that was with their windows closed!!!!
Would like to see them run in the open drag classes though!
