Page 3 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 31 to 45 of 110
  1. #31
    N/A
    Quote Originally Posted by tunnels View Post
    Take your blinkers off and join in and post your thoughts and lets hear your constructive comments instead of getting all agro !! the more people that join in the better the more ideas there are and the more we can share and help others !!
    This reads like a uni body vs full steal frame conversation from the 1970's. From a high level can you detail the rapid prototyping to manufacturing process? How is the mold and structure fused flashed and what time frame does this of process take from CAD -> Water? Thanks.
  2. #32
    Jul 2007
    Have lived and worked in New Zealand ,Tahiti,Australia,Japan , south Korea, And now Suzhou in China
    Quote Originally Posted by kelvin523 View Post
    What are you referring to ??does any of this have anything to do with stringers ??or did the cat walk over the key board on your computer ??
  3. #33
    unibody is hull without stingers, monocoque
    Hull that needs stringers is a chassis to hold it together
    clear to me?
  4. Likes AZMIDLYF liked this post
  5. #34
    Jul 2007
    unibody is hull without stingers, monocoque just a bare hull
    Hull that needs stringers is a chassis to hold it together stringers don't hold it together all the do is strengthen longitudinally !!
    clear to me?
    well those are some very un nautical terms but I get the idea sort of! as for the rest of that post well id hate to ask directions to the nearest toilets if I need to go in a hurry !!
    Is that classed as modern day language taught in schools ?? no wonder the worlds I such a mess !
  6. #35
    Mar 2015
    DFW
    interesting that you reprimand the man about language when your posts are harder to read than chinese algebra...
  7. Likes AZMIDLYF liked this post
  8. #36
    N/A
    Apologize, must have misinterpreted this original post. For those interested in current and next generation capabilities, enjoy.
  9. #37
    Kelvin just ignore Tunnels. He is an arrogant know it all. Obviously over in France you would have a slightly different way of explaining something however all us American friends understood exactly what you meant by uni body and frame rails. Now lets just wait for his petulant rebuttal.
  10. #38
    Jul 2007
    And so history repeats it self yet again ? , back for more of the same are we?
    be nice, be kind and stay on topic of the thread !If you want to be good say something intelligent that we can all learn something from !
    Thank you !
  11. #39
    Jul 2007
    [QUOTE=Noah Burns;2981017]interesting that you reprimand the man about language when your posts are harder to read than chinese algebra...[/QUOTE
    Seriously now stringers is what this is about or it started off to be so if its nothing to do with them im outta here
  12. #40
    Yeah Tunnels you just cant help yourself. You try to look interested but first chance you get to ridicule someone your on it. Guess thats your human nature. You are pathetic.
  13. #41
    Jul 2007
    Stringers ! What is the most common glass used to glass over or attach them to the hull ??
    Most of what iv seen in the past guys have used woven glass and its possibly one of the worst types of glass to use in that situation !, only 50% of the glass strands are really doing anything towards holding the stringer in place ! 0/90 bia axle is the same scenario !!
    The orientation of the glass fibres is the key to getting the best from the glass used always !!
    Double bias 45/45 is a whole different story 100% of the fibres are holding the stringer on place !
    Something else when fitting and glassing stringers is having a decent sized cove along the bottom edge to wrap the glass around a radius instead of being forced into a dead right angled corner !! even at the best of times glass does not like corners and it reduces the strength of the glass quite significantly, a radiused cove increases that strength and its far less likely to break if there is any great loads placed on the stringers !
  14. Likes FMP, One Oldman liked this post
  15. #42
    I don't think you've mentioned that before
  16. #43
    Jul 2007
    Quite possible !! its pretty important to be able to get all the glass in the different parts of a stringer all working together !!!
    The same principles of glass orientation apply to making grids as well , The vertical sides get placed in compression so the glass needed has to be able cope with compression as well as buckling in extreme situations if huge loads such as hitting a solid object !!
    Then we have a completely different situation needed for the top of the stringer and extreme stretch is applied as it wants to bend upwards so a different orientation of the glass fibres is needed to cope with extreme stretch without breaking .
    A stringer in effect becomes an" I " beam so has to be built appropriately ! so when choosing glass to make a stringer there's many things to consider and just one kind of glass is never appropriate !!
  17. #44
    N/A
    moulded fibreglass grids are definitely the way of the future , they are accurate ,they fit where they should !! there is no guess work involved ,They can be made much lighter than any wood stringer system that has to be glassed in any way and the chances of the wood becoming rotten in a few years time PLUS the glass holding the wood in place delaminating off the soggy wet heavy wood so in reality it the glass that's there that's doing the work not the wood !! so why bother???
    Glass one off grids can be made from sheet glass same as what's used normally just takes some thinking about and fitting properly and glassing in place !!
    Thanks again. I'll start a thread sometime in the future on cad->cam->water (2 weeks to print - 2 week to assemble). I was really interested in the molded fiberglass grids, do you have pictures and/or supplier details?
  18. #45
    Jul 2007
    ok have very quickly skimmed across the glass and glassing of the stringers but there's the mounting pad of a stringer that's equally important for people doing the ply in edge thing !!
    A couple of things to take into consideration !, Did you build a strengthening pad for the stringer to sit on ??? Are you going to cove the corner full length end to end both side ??
    Both those things are important , More so if the is no core it really needs a pad and even with a balsa core specially ! foam distributes the load better over a wider area , where as Balsa is much more localised !!
    Vertical high narrow ply stringers can simply break or worse still layover on there side when places under enormous loads such as hitting something solid !!!.
    Foam stringers would be much wider and thicker and would heave a bigger foot print so would distribute loads over a much much wider area !
  1. Stringers is the subject !!
    By tunnels in forum Fiberglass and Composites Discussion
    Last Post: 03-18-2017, 06:01 PM
  2. Whats everyones opinion of the '88 Johnrude 140 looper?
    By NH LTV in forum Technical Discussion
    Last Post: 05-02-2011, 08:52 PM
  3. Ummmm...Why Is Everyones Post History Gone?
    By AirRide in forum The Scream And Fly Lounge
    Last Post: 05-24-2010, 03:24 PM
