Results 1 to 15 of 59
Thread: T2x/tillotsen carb rebuild kits
08-09-2017, 07:53 AM #1
I know Chrysler/force used tillotsen carbs. Does anyone know an application that I can order carb kits for?
08-09-2017, 09:07 AM #2
The Historic Photo Master
- Jan 2004
- Florida
- 38,759
- 78
- 1778
- 385
- 20531
- 4 Post(s)
...This should be the "repair' kit. Has more pieces to it, than a rebuild kit. Hard to find.
08-09-2017, 09:10 AM #3
- Jan 2004
- Florida
- 38,759
- 78
- 1778
- 385
- 20531
- 4 Post(s)
www.carburetor-parts.com Mike has a number K-5004 "rebuild" kit. Don't know if it will help you or not. What numbers are on your carbs? Parts & pieces(carbs) get changed over time.
08-09-2017, 09:14 AM #4
I think any 120+ hp 4 cly, Chrysler/force will work , If you look through Droll's posts I think he listed specific kits .
mrcrsr liked this post
08-09-2017, 09:35 AM #5
Thanks guys, I'll try and get the carb numbers tonight. It's been a pita trying to get the correct pistons for it. Looks like special order wiseco is going to be the only route.
08-09-2017, 10:40 AM #6
TSM performance has rebuild parts for Chrysler / force.
What are you looking for? I use MarineEngine.com and Crowley marine... take the part numbers, and often cross-reference them on Amazon.com. Usually, the websites themselves are cheaper than amazon! Often, individual carb pieces needed are cheaper.
What's the engine you're working on?1) 1995 14' Bayliner Restoration <--Click
2) Home-Made Tunnel-Boat Project <--Click
08-09-2017, 11:12 AM #7
Screaming And Flying!
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
TC1A or ?
08-09-2017, 04:32 PM #8
if you contact tillotson they still sell carb kits for the TC carbs.
08-09-2017, 04:43 PM #9
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
The later TC as found on F5 etc are a bit different than the earlier ones.
08-09-2017, 07:08 PM #10action mobile marine, 772 528 0754, dealers for aces fuel products,wolf efi, pro marine,latham and gaffrig/livorsi. we build gearcases and modify them(3 litre) to ratchet, and powerheads as well. 21 skater/3 litre wolf efi 113 mph the engine build http://www.screamandfly.com/showthre...-3-litre-build
08-09-2017, 07:08 PM #11action mobile marine, 772 528 0754, dealers for aces fuel products,wolf efi, pro marine,latham and gaffrig/livorsi. we build gearcases and modify them(3 litre) to ratchet, and powerheads as well. 21 skater/3 litre wolf efi 113 mph the engine build http://www.screamandfly.com/showthre...-3-litre-build
08-09-2017, 07:14 PM #12
Here's another question also, the other engine I have has carbs that are slightly different, the first set from the above number has 2 tubes going up inside the Venturi, the second set off the other engine have 1 tube in the Venturi. Which is a better set to use. A friend said that the carb with the 2 tubes is better. Here is the part number off the other carbs.
08-09-2017, 07:25 PM #13
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
The other TC?, Any of the earlier 123456A are virtually the same.
08-09-2017, 07:32 PM #14action mobile marine, 772 528 0754, dealers for aces fuel products,wolf efi, pro marine,latham and gaffrig/livorsi. we build gearcases and modify them(3 litre) to ratchet, and powerheads as well. 21 skater/3 litre wolf efi 113 mph the engine build http://www.screamandfly.com/showthre...-3-litre-build
08-09-2017, 07:39 PM #15
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
I think the earlier TC1A may have had the single pick up tube. I'd have to ask the 135/15O Stacker Bill Edwards to be sure. Maybe they had two version. The TCs I have all two tubes I believe, going to check.
Ebay Rebuild Kits
By Fisher77 in forum Technical DiscussionReplies: 8Last Post: 05-10-2016, 07:34 AM -
WH-20 carb rebuild kits
By Derrek Curtis in forum Technical DiscussionReplies: 3Last Post: 02-02-2007, 09:35 AM -
OMC rebuild kits ?
By Rmart30 in forum Technical DiscussionReplies: 5Last Post: 01-29-2007, 02:49 PM
