    Fond du Lac WI
    I think I rigged that one and we did a BHB on it and then some photos. ActionCraft wanted 50 MPH - I was stuck at like 49.8 radar. Took it in the shop - drilled out the carb jets, viola! 51 and change!
  3. #6813
    it went faster when it was richer???
  4. #6814
    If you drill out opti carb jets they do.
  5. Likes powerabout liked this post
  6. #6815
    Fond du Lac WI
    OK that wasn't the boat - didn't notice the decals - just the back one. It was a 135 carbie I did that to. Memory is going fast - hell, it was only 15 years ago.
  7. #6816
    ...Mercury Racing - Go Fast, Go Boldly! - https://youtu.be/US7g2DFuWi8
  9. Likes powerabout liked this post
  10. #6818
  11. Thanks joyrider thanked for this post
    Likes powerabout, Capt.Insane-o, joyrider liked this post
  12. #6819
    Fond du Lac WI
    Or this:Click image for larger version.
Name:	merc 650xs.jpg
ID:	383366 Or this:Click image for larger version.
  13. Likes joyrider, Capt.Insane-o liked this post
  14. #6820
    South Florida
    What lower unit is on the 700X? It would seem that a single pinion lower unit would be sufficient for a 49in motor.
  15. #6821
    Fond du Lac WI
    Quote Originally Posted by 2us70 View Post
    From what I have heard it was a 16/23 ratio with one driveshaft and pinion. Don't know that for a fact, but makes sense.
  16. #6822
    South Florida
    I wonder if that ratio would allow it to use props for the larger speedmaster motors? Mercury practice was to make props for the larger motors usable on smaller motors running the same family of lower units. The 50s could run the 650 props and the 850s the 1500 props.
  17. #6823
    Quote Originally Posted by bernie View Post
    The Hi Perf catalog says they had 13/16 ratio. Rumor is that std motors came with single pinion, but motors that dyno'ed 'extra' came with dual pinion. I think its more likely that Merc set some up for marathons vs sprint ... could be that the marathon motors were indeed 'extra' hp motors sent to specific racers
  18. #6824
    Quote Originally Posted by Mark75H View Post
    Omc Started to race mod 50 with one pinion late in the game
  19. #6825
    Fond du Lac WI
    Yeah, 13/16 ratio - senior moment on that gear ratio. Saw one of the Merc 49 CID looper powerheads a month ago in Canada - now I have seen two of them - I think there were only 5.
Page 455 of 1894 FirstFirst ... 355 405 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 505 555 955 1455 ... LastLast
