Results 46 to 60 of 70
08-04-2017, 07:45 PM #46
Can you run it 5700 for several miles..........lol
08-04-2017, 07:50 PM #47
Team Member
- May 2009
- 2,294
- 704
- 135
- 917
- 518
- 7 Post(s)
"padded wonder"
__________
the wet:
18’ Bahner bow rider, 2.4/200
the dry:
2003 bmw ///M5
and a handful of clunkers
08-04-2017, 07:52 PM #48
That's what they were made for.
pcrussell50 thanked for this post
08-04-2017, 08:11 PM #49
5700 thats almost the sweet spot with 26 pitch you should be going 70 +
08-04-2017, 08:40 PM #50
Team Member
- May 2009
- 2,294
- 704
- 135
- 917
- 518
- 7 Post(s)
Good to know, guys. Thanks.
-Peter"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
08-05-2017, 06:42 AM #51
@6000 you will be tired,and ready to go home before the 2liter is!!
roadkill636 liked this post
05-22-2020, 12:44 AM #52
Team Member
- May 2009
- 2,294
- 704
- 135
- 917
- 518
- 7 Post(s)
1987 2.0l 150...
Didn’t want to start a whole new thread for this...
Motor’s been running pretty well the last three years or so as I slowly uninstall various “bugs” put in by previous owners. Just fixed a float that was sagging too low and probably not closing all the way when full. Now it runs even better (smoother idle). Though it didn’t seem to hurt the mid-high end.
So anyway on to the next question... the link bar that connects the throttle cam to the throttle arm... How do you take that mofo off, and is there spec for how far you adjust the link bar? I have the factory service manual and it says nothing about in the link and sync section.
Where would I look in the manual for information on how to remove and adjust it?
__________
the wet:
the dry:
2003 bmw ///M5
05-22-2020, 05:01 AM #53
That dude should just unscrew from timin arm. I always bottom the threads out then loosen it a few turns , if u leave it tight it wont work rite
05-22-2020, 06:07 AM #54
ya gotta pull throttle/timin' arm, rod and cam off as an assembly.. then ya can unscrew all tha pieces..........
Go Time liked this post
05-22-2020, 09:01 AM #55
Team Member
- May 2009
- 2,294
- 704
- 135
- 917
- 518
- 7 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
05-22-2020, 09:11 AM #56
there are two, or should be, springs.. one which is what i call "inside" of tha two arms.. tha circle part where tha two arms come together.. it will stay put if your carefull after removing tha 9/16 bolt (last thing ta remove after you remove tha trigger nut and tha cam nut) that holds it all on tha block.. tha other, if its there, is a half moon shaped that acts kinda like a "return" spring.. jus pay attention when ya pull tha things and all will be well.............
05-22-2020, 09:32 AM #57
tha half moon is outside tha assembly.. it has oppsite bent tangs on each end.. one tang goes in a hole on tha block and tha other tang goes ina hole in tha throttle arm part around tha 9/16 bolt and bushing.................
05-23-2020, 11:34 AM #58
Team Member
- May 2009
- 2,294
- 704
- 135
- 917
- 518
- 7 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
05-23-2020, 12:05 PM #59
its not really.. neither one are after ya do it a coupla times...
donno why it doesn't???
05-23-2020, 05:36 PM #60
Or u can add a spring to head bolt like hipo motors , that's what I did. Its snaps back better without putting to much tension. I actually forgot about the half moon one , I have a 150 with it still on but others I never put back, prob just forgot bout it b honest, or gone when I got em
