    Fond du Lac WI
    Bernard...You probably utilized the lower mounting bolts/hydraulic fittings, that came standard on the first generation(1976-79) Mercury V-6 O/B, in Figure 1, Item 15A, above. They were still available in the early eighties. Maybe you came up with the idea in the field as an answer to the first generation 3.4 gearcase water intrusion issue, that was found to be caused by a water pump base design, that leaked? Mercury updated the 3.4 water pump design two or three times in the first years of the consumer 3.4's.
    ...along with the 70's/80's MerCruiser drive reservoir bottle...?
    Could have been - I was on the 3.4 task force to get that big bitch runnning right - dual bearing pinions, the Cosworth block , better bearings, you name it - in the end it was a pretty good motor, my estimation. Needed EFI, intregal trim, and bucket cowls, and some marketing - but the 3.0 was already being designed and that ended the 3.4.
  2. #6707
    the 3.0 was being designed way back when the 3.4 was running?
  3. #6708
    Fond du Lac WI
    I was in Product Assurance testing in 1988 and we were about to run a batch of pre production engines - well beyond the proto stage then. Would imagine 3 years prior for sand cast proto's.
  4. #6709
  5. #6710
    ...Multiple World and National Offshore Championships - Power By Mercury -
  6. Likes FMP liked this post
  7. #6711
    That a good picture
  9. #6713
    ...UIM World Offshore Championship - Power By Mercury -
  10. #6714
    ...F1H2O UIM World Championship...Power by Mercury...
  11. Likes joyrider liked this post
  12. #6715
    ...Victory Team - Mercury Powers These Winners...
  13. Likes joyrider liked this post
  14. #6716
    Quote Originally Posted by Robby321 View Post
    Bird cage liner
  15. Likes Dave Strong, Capt.Insane-o liked this post
  16. #6717
    Quote Originally Posted by Mark75H View Post
    Bird cage liner
    Bullchit Sam......relics the old days and STILL needed..........many
  17. Likes Dave Strong liked this post
  18. #6718
    Bird cage liner
    Those old ones were way better than the new ones.
  19. #6719
    Just need the real Merc ones. They are around, have a few myself.
  20. #6720
    Can't take credit for this one!!!!Gary
  21. Likes Dave Strong liked this post
Page 448 of 1894 FirstFirst ... 348 398 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 498 548 948 1448 ... LastLast
