Results 1 to 10 of 10
07-20-2017, 08:00 PM #1
2.5L EFI-Offshore Exhaust Block-off Plate
I'm currently running without an exhaust block-off plate on my offshore mid-section.
Am I hurting my performance by not using one?
What are the pros and cons of running with one and without one?
Are the differences that significant?
As the motor did not come with one, I'd have to order one; would it be worth it?
07-21-2017, 09:31 PM #2
5000 RPM
- Jan 2013
- SE MN
- 864
- 44
- 145
- 63
They have so many holes I doubt there is a noticable performance difference. I plug most of mine to make it a little quieter when at the local lake with sheriffs around. They seem more like a sea strainer than anything else.
CHICKENHAWK thanked for this post
07-21-2017, 10:52 PM #3
07-22-2017, 06:20 AM #4
Member
- Jun 2014
- Denmark
- 41
- 21
- 32
- 13
You will ventilate the prop more with plate. I dont see any speed difference
Torben
07-22-2017, 10:23 PM #5
5000 RPM
- Jul 2005
- Baton Rouge, LA
- 723
- 26
The factory one is like Swiss cheese and wasn't noticeable on mine. I ended up making a solid one that I use if my wife and daughter are in the boat. (She's 2 and doesn't like loud noises) It does force all the exhaust through the prop so it will act like a regular mid.
07-22-2017, 11:57 PM #6
07-23-2017, 12:04 AM #7
5000 RPM
- Jan 2013
- SE MN
- 864
- 44
- 145
- 63
1/8 ss or 3/16 aluminum should be plenty. Gasket optional.
07-23-2017, 12:34 PM #8
5000 RPM
- Jul 2005
- Baton Rouge, LA
- 723
- 26
I just had a piece of aluminum I used. Haven't bothered with a gasket.
07-23-2017, 04:06 PM #9
Interesting....
Some offshore housings have no relieves at the top. The 1 piece adapters covers them. Now if you close the offshore snout 100% off there is no idle exhaust relieve anymore above water. Someone having problems due this?
07-23-2017, 08:04 PM #10
5000 RPM
- Jan 2013
- SE MN
- 864
- 44
- 145
- 63
My idle relief slots are open. Appear to be factory stock and exhaust comes out of them.
Exhaust block off plate?
By Flatlander in forum Technical DiscussionReplies: 0Last Post: 06-19-2013, 03:01 PM -
By surh56 in forum Technical DiscussionReplies: 1Last Post: 11-13-2007, 04:17 PM -
Exhaust Block Off Plate
By bscotti in forum Technical DiscussionReplies: 2Last Post: 03-11-2004, 03:36 PM
