Results 1 to 15 of 21
07-12-2017, 03:16 PM #1
Mercury 300xs Oil Injection System Question
Ok, I'm so used to pre-mixxing my oil this system has me 2nd guessing myself.. question is
I primed the system as the manual says - Turn on the key, pump throttle forward 3 times and allow system to prime.
No problem, sucker drank down almost 1/2 the oil tank on the engine..and called it a night as the bugs were biting.
This morning I noticed this oil line running into the oil injection pump looks clean and dry, like not oil was pumped to the injector pump.
Should this line show oil? (Clear line with white breading)
07-12-2017, 05:20 PM #2
I will check mine later this eve. It's been setting since Sunday
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
07-12-2017, 07:44 PM #3
Mine still has oil in hose. I would re-run the prime again and then check.
07-12-2017, 08:19 PM #4
The prime will not push oil from the tank to the motor reservoir, it takes pressure from the motor when it's running to pressurize the remote tank and push oil back into the motor tank. The procedure to refill the motor tank is to crack the reservoir cap when you start the motor and carefully watch as the reservoir fills up then close the cap just as the reservoir fills up, this purges the air from the system. It will fill quickly once pressure builds so be quick to close the cap or you will have a bit of an oil spill to clean up.
Mark
07-12-2017, 09:02 PM #5Checkmate 2002 Convincor 270 496 MAG-HO
07-12-2017, 10:27 PM #6
07-13-2017, 10:07 AM #7
This is almost comical so bare with me..
I primed the oil system again (4 times total now) and more than 1/2 the oil in engine mounted tank was sucked through, so the motor had oil.. yet the hose still looked clear. So I removed the hose entering the pump and... ready for this, Mercury used a gold'ish color oil in the system for break in.. lol. I was expecting blue oil.
I refilled the engine oil tank with Hi-Perf (blue) oil and fired the engine.. I smoked the yard heavily and you could slowly see the oil in the line change color.
So long story short, I was worried about nothing...
07-13-2017, 11:17 AM #8
5000 RPM
- Sep 2012
- Florida
- 447
- 15
- 9
- 85
Better to be worried about nothing than not to be worried about anything!
07-14-2017, 07:38 AM #9
Opti oil is gold not blue...that line is full....be careful with priming the oil pump more than once as i have seen guys who thing if once is good 5 times is better and they hydrolock a cyl on oil.....
1984 28 ghost twin 200 Yamah ProVs (SOLD)
1997 21 Superboat Legend 250 VMAXXX (SOLD)
2001 25 Concept CC 250EFI (SOLD)
2002 24 Superboat Step 250EFI (SOLD)
1997 21 Checkmate Pulsare 200EFI Merc (Beater Boat)(SOLD)
1994 20 Hydrasport 225 Optimax (SOLD)
1998 27 progression Twin 225 Mercs (SOLD)
2005 23 Kryptonite 300 Promax (SOLD)
07-14-2017, 09:21 AM #10
Actually, the high performance, aka Mercury Racing oil is red, not sure what the blue stuff is.
Mark
07-14-2017, 09:23 AM #11
07-14-2017, 09:43 AM #12
I'm not sure about the XS but going in and out of gear with engine off but key on a bunch of times may put you back in break in. Ghost is correct DFI oil is gold.
07-14-2017, 09:55 AM #13
They don't make it easy, they specify one oil in their brochure and another in the owners manual.
Here is an official response from Mercury regarding the recommended oil for the 300XS, "The customer should be running the Mercury Racing 2 Stroke Oil, which is part # 8M0078011. The current labels are the blue foil labels. The black and yellow label is the same product but it is just a bit older than the blue foil label.".
This is the old label:
This is the new label: (sorry for the low resolution)
Both of these are red.
Sorry, didn't mean to turn this into an "oil" thread.......
Mark
07-14-2017, 10:13 AM #14
07-15-2017, 11:40 AM #15
And this is from my 300xs Mercury factory repair manual...! Got to wonder why there are so many topics on oil!
1992 2.5 Mercury 200hp long block with injection system
By StratosVT in forum Outboard EnginesReplies: 9Last Post: 11-11-2014, 11:56 AM -
Mercury Tech: Mercury oil injection question
By wired247 in forum Technical DiscussionReplies: 0Last Post: 07-02-2012, 11:05 PM
