Results 1 to 15 of 15
    Apr 2013
    Lexington, ky
    Question Carb tuning questions
    Can a carb be jetted correctly using a test wheel and leaving the boat on the trailer or even using a regular prop while on the trailer and trimming up until the engine reaches the RPM where you want to check jetting? I have trouble around here finding a place to run my boat for a long stretch at high speed/rpm. Most all the lakes are short and the river is curvy with some short straight stretches.
    I thought about using a 22p chopper and riding the river so the RPM with be high with low speed or just backing the boat into the water using the 22p chopper as a test wheel and holding it at whatever RPM I want to jet for. Not sure about the best or most accurate way to do this and still be manageable doing by myself since I don't have anyone close around that understands what the hell I am trying to do or how things work.
    Slimm
  2. Likes Glasstream15 liked this post
    Jun 2016
    toccoa ga
    Not sure about where you live but you better check the laws on what you are talking about doing with the prop on the ramp. It's perfectly fine here but a buddy of mine got a ticket a few years back using engine power to trailer his boat while on vacation out of state. Where ever he was claimed it damaged the concrete ramp and the fine was around 1500 bucks.
  4. Likes Slimm liked this post
  5. #3
    How the heck can running a mota damage the concrete ramp?
    If you do it at the ramp dont trim the mota up. Instead back the trailer into the water far enough with the enging all the way down untill the cavatation plate is JUST touching the water. And have all the straps holding the boat on. And throttle up. The prop will suck in air and let the enging rev but still give it some load.
  6. Thanks Slimm thanked for this post
  7. #4
    Apr 2013
    Lexington, ky
    A lot of ramps won't allow power loading like that because they claim it washed the gravel/sand/rock/dirt etc. from the ramp's edge which can cause the end of the ramp to break off. Everyone I have seen since I was a single digit age power loads their boat with no problem or ill effects.
    Thanks for the suggestions, appreciate it.
    Slimm
    Quote Originally Posted by roadkill636 View Post
  8. Likes Glasstream15 liked this post
  9. #5
    Wow a fine, those keystone crooks saw him coming. Unless you're under full load and rpm running on water the load will most likely be a lot different on the ramp. Too rich may go unnoticed till you hit open water. Maybe if you checked plugs after a tuning session.
  10. #6
    Quote Originally Posted by SlimmDaddy View Post
    Slimm
    Direct drive and V drive wake boats make a mess of the ramps.
  11. Likes Glasstream15, Slimm liked this post
  12. #7
    Sep 2006
    Minnesota
    On power loading. In the south where ramps are built long enough and with the right slope, power loading is not a problem. Here in the red star state (MN), many of the ramps are complete junk, and power loading will wash out the fill around them. Some are even linked concrete ties so power loading will wash the sand and gravel out from under the ramp. Angles, depths, etc are all over the board, and have no relation to reality most of the time.
    I power load where I can, but there are some landings where I just have to crank it on the hard way.
    To fish or not to fish? What a STUPID question.
  13. #8
    Quote Originally Posted by Dave Strong View Post
    Dave I think they make a mess of everything...... starting with no concern for their wake or the damage it does!!! Gary
  14. Likes Dave Strong, Slimm, CHICKENHAWK liked this post
  15. #9
    You know it.
  16. #10
    Sep 2015
    Twin Cities, Minnesota
    almost nothing worse than a wake boat driving in circles creating 3' tall waffle pattern waves while your trying to drive across them. Only one laughing is the wake boat owner and his 95k payment plan.
  17. Likes Slimm, olboatman liked this post
  18. #11
    May 2014
    Livingston, Louisiana
    Or trying to fish in them Yet he'll be the same fool to throw a hissy if you pass his "camp" making too much wake
  19. Likes Slimm, olboatman, tunnelmike liked this post
  20. #12
    Baton Rouge, La
    If he's referring to a f1 testwheel they don't create prop wash like a conventional prop but put a load on the motor. I do agree you will loose the battle with a water cop pleading this point.
    Power loading causes the prop wash to swirl and undermine concrete ramps causing some to collapse thus damaging the concrete. Hope this helps. Mike.
    Cheaters never Win !!!
  21. #13
    Mar 2010
    houston, tx
    Could have used a test wheel today
    drop boat in, make hit
    take boat out make change
    drop boat back in all day :/
    still weird issues.
    Started out day with one issue now have 3 hahahaha
  22. #14
    Sep 2015
    I hear ya there
  23. #15
    May 2014
    Sorry to hear you still having issues. Just hang in there it'll all come together. Gotta love these agrivating things sometimes! Good luck to ya, and hope it all works out!! May just need to take a break and go fishin to clear ya head Or if you like me might make it worse lol
  1. WMH carb tuning
    By crazy cajun 2 in forum Technical Discussion
    Last Post: 01-07-2008, 12:08 PM
  2. more tuning questions???
    By rchevelle71 in forum Technical Discussion
    Last Post: 10-19-2007, 08:41 AM
  3. tuning 2.5 carb
    By 235spd liner in forum Technical Discussion
    Last Post: 06-10-2007, 06:51 PM
  4. Mod V4 Tuning Questions
    By Laker in forum Technical Discussion
    Last Post: 07-25-2002, 01:13 PM
  5. More Inline Tuning Questions
    By XSRaveau in forum Outboard and Racing History
    Last Post: 05-11-2002, 09:26 AM
