				Results 121 to 135 of 182
	06-24-2017, 10:13 PM #121I have never seen a bubbleback V-4 that the chest was not cut..... just sayin' "One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
	 58Evinrude liked this post 58Evinrude liked this post
	06-25-2017, 01:18 PM #122
	06-25-2017, 01:58 PM #123Ok guys gathering all the info needed for my build. But and its a big BUT
 Should i Square of the ports r just leave them as is?
 If i leave them as they are Should i remove the "Tits"
 Some say Square some say Leave
	06-25-2017, 03:28 PM #124
	06-25-2017, 04:39 PM #125Please correct me if I'm wrong, but I think '85 was the last year for the xflow 140. They detuned it with lower compression (thicker) head gaskets and different jetting. And it became the bubble back 115 (prop rated). Should have the exhaust chest cut, and reed stuffers. Prior to that the 115 was a flat back.
 I have a running '79 115 w/good compression on a stand in the craport that I hope to tear into/140-ize soon. Gonna go on the Baja after I hang my 140 on the Speedcraft.'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
	06-25-2017, 04:43 PM #126'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
	06-25-2017, 04:51 PM #127
	06-25-2017, 04:54 PM #128"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
	06-25-2017, 05:02 PM #129'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
	06-25-2017, 05:15 PM #130Ya got me curious enough to go check my 115. Its a 91, not mid 80's like I thought. And the exhaust is cut. Just have to pull the reeds out and see if there are stuffers in there. Any idea just what sort of hp I might be able to make from this? I have an early 80's 115 on my Winder now, I know its really a 90 in prop hp.
	06-25-2017, 05:15 PM #131
	06-25-2017, 05:18 PM #132
	06-25-2017, 05:20 PM #133'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
	06-25-2017, 05:33 PM #134'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
	06-25-2017, 05:35 PM #135Seriously I've had pretty good luck on "junk" buys. Just gotta know what kinda junk ya wan't and how much yer willin to pay for it? '71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
  Need help removing lower unit on johnson 85hpBy faster100 in forum Technical DiscussionReplies: 16Last Post: 06-17-2017, 03:48 PM
  Wanted: MINT 1978 or 1979 Johnson 85HP cowlBy FlowMaxx in forum Parts WantedReplies: 2Last Post: 09-19-2014, 03:08 PM
  OMC Tech: '77 85HP Trim help neededBy turbotadd in forum Technical DiscussionReplies: 4Last Post: 05-15-2009, 09:39 PM
  85hp johnson heads offBy phillnjack in forum Technical DiscussionReplies: 1Last Post: 04-05-2005, 05:34 PM
 Thanks:  Likes:
  Reply With Quote Originally Posted by 58Evinrude
