    South Florida
    We had an older motor without that provision (might have been a 44ci Merc 400). We made an adapter plate from plate aluminum. Worked great for about a year but then the driveshaft splines started to fail. That adapter caused the driveshaft splines to not engage fully so Brooke Russell sleeved and pinned a slightly longer top end on the shaft. Over the years I suffered just about every common failure from breaking off the top of a crank to breaking out the rear bearing carrier in the lower unit and most of the stuff in between. I learned a lot and with the help of a few knowledgeable friends I got so I could make the 500s run pretty good and pretty reliable too.
  2. #6347
    Fond du Lac WI
    Heres just a pretty picture of mine - now being replaced by a 650XS.Click image for larger version.
  3. Likes FMP, Robby321 liked this post
  4. #6348
    5 Post(s)
    ...Had the exact same 14' CheckMate Bernie. Green metalflake. Louvered blue-stripe J-motor. Ran unusually well considering it's rounded V-bottom. You did a nice job cleaning that one up. Looks great.
  5. Likes FMP liked this post
  6. #6349
    South Florida
    That's nice. A real classic.
    I will have to admit that I probably made every tuning and setup mistake in the book on those motors. Hell,I probably added a couple to the book but it was all a learning experience and great fun.
  7. #6350
    South Florida
    I have driven several 15' Checkmates with J motors and if you can manage a 14 with one you have my admiration.
  8. Likes Capt.Insane-o liked this post
  9. #6351
    South Florida
ID:	376468My Action MX13 clone with 3cyl 650 in 1973
  10. #6352
    Fond du Lac WI
    It actually is a 1968 131, 13'. Orignally owned by the Kiekhaefer Corporation, and was a playtoy of Freddy hisself. Fred verified that for me when he recognized the deck mounted tach tube and the forerunners to K-Planes, built by JD Emerson at the Lake - which is cool because I know JD also. Fred sent me a "Dialed in at Lake X" decal, its on the dash. It says "dialed in at Lake X" and then is autographed "by Fred Kiekhaefer". During my resto process I found the Click image for larger version.
ID:	376469Click image for larger version.
Name:	Checkmate Tomahawk.jpg
ID:	376470Click image for larger version.
Name:	Shiny stuff 001.jpg
ID:	376471Click image for larger version.
ID:	376472Kiekhaefer Corp property tags for the boat and trailer! The seats I had reupholstered but that back tank cover is original upholstery! Also has early tilt wheel Ride Guide! I did respray the deck but the rest was just buffed up. Bottom has about 3 feet of SuperGlide at the keel. Getting close to trying it with the 650XS, some rigging to finish. Check out those original 50 year old transom bolts!
  11. #6353
    South Florida
    A word of warning. Those MX13s did not play well with the 650 lower units. Lots of prop blowout. I found them to handle better with the big units on the 850s in G class. I got my 13' Action cheap because the first owner spun it several times and scared himself. I managed to make it better but every once in a while it would try to go sideways.
  12. #6354
    I had that motor as well, strong and great looking. Turned a two blade, seems strange now.
  13. #6355
    Fond du Lac WI
    Quote Originally Posted by 2us70 View Post
    Maybe thats why there is a fin on one of the tabs? The boat had something bigger on it at some point in time, found big bracket bolt holes and a PT harness tucked away under the gunnel. I will work into the XS with caution. Thanks!
  14. #6356
    5 Post(s)
    ...1968 CheckMate/Mercury...
  15. #6357
    Fond du Lac WI
  16. #6358
    Quote Originally Posted by bernie View Post
    How were those tabs adjusted?
  17. #6359
    5 Post(s)
    ...Fred Kiekhaefer(previous president of Mercury Racing) and family friend & business partner Rex Runzheimer will be introducing the long awaited & much anticipated new K-Drive, initially behind diesel power. Rex owns Runzheimer International in Wisconsin, who's business is workforce mobility programs & related mobile workforce management, commercial real estate, etc., among many other businesses. Rex is the manager of the recently formed Miami Florida corporation KDrive, LLC. The new testbed boat is a Cigarette...or is it a NorTech...or...? In just a few more weeks we will have more exciting news regarding this new drive system. (file photo)
  18. #6360
    5 Post(s)
    ...K-Drivers...skiing Colorado...
Page 424 of 1894 FirstFirst ... 324 374 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 474 524 924 1424 ... LastLast
