Results 1 to 13 of 13
05-15-2017, 12:12 PM #1
SSSM driveshaft question for old inlines.
So I guess I have never understood the reason why some of the SSM on inline motors had a full length one piece driveshaft while others utilize a lower stub driveshaft with a intermediate one. I guess this was kind of common on the SBP lower units but can someone explain the reason why ?
05-15-2017, 12:33 PM #2
7000 RPM
- Dec 2005
- 2,120
- 647
- 290
- 1929
- 958
- 3 Post(s)
Tom--the SBP on the Offshore boats came with two different lengths--Maybe it was easier to inventory two driveshaft lengths than to inventory two different Lower Units?
The original BP driveshaft was a two piece/rubber coupled affair that had a service life of about 60 minutes--
05-15-2017, 12:47 PM #3
5000 RPM
- May 2003
- Fond du Lac WI
- 815
- 18
- 85
- 72
- 408
Stub shaft SSM - maybe for MerCruiser use?
05-15-2017, 03:11 PM #4
7000 RPM
- Dec 2002
- South Florida
- 2,101
- 170
- 597
- 13 Post(s)
Looks to me that the stub shaft unit would be easier to change in a hurry. I recall guys pitting for lower unit failures in some of the longer endurance races. In the 9 hour you had to already have it in the boat and change it with tools also on board without outside assistance.
05-15-2017, 03:34 PM #5
I wuz thinkin that the two piece driveshaft would allow for a rubber coupler to maybe help absorb the shock of shifting on the SBP lower? I don't see how it would increase time to change lowers as you still would have to insert and hold the intermediate driveshaft somehow. Seems like a once piece would be easier and quicker.
05-15-2017, 03:35 PM #6
05-16-2017, 09:56 AM #7
Yep the BP had two different mid lengths like Gene mentioned.
I see lots of SSM's with mid shafts. I think when the T2X came out with its shorter mid section length lots of 15 inch SSM's got chopped and used an intermediate shaft.
Using an intermediate shaft would let you put the lower unit on more than one motor without taking the driveshaft out and messing with gear set up which is a huge pain.
You could have a T2X mid shaft and a STD 15 in MID shaft for a SSM and run that lower unit on various applications very easy without much time involved.
I don't think Merc ever used a mid-shaft for the SSM's. It was racers doing so.L6fan57-88
05-16-2017, 10:41 AM #8
T2X when it came out had a unique length single piece driveshaft from the factory to go along with its 12 inch mid length.
Likewise the MC-1 driveshaft ( single piece) that came out before the original Twisters were an inch shorter than a standard 15 inch which the SSM used. These motors require the hard to find shorter adapter housing if you want to run them on a standard BP mid or fishing motor 15 inch mid.
Or you need a good bolt stretcher to use on the driveshaft.
you can see from this chart that the XS and T2 basically use the same standard length driveshaft. Everyone else came from a different planet I guess. EK must have had his reasons.......
Notice no mention of the standard SSM or the BP 's.
05-16-2017, 01:57 PM #9
The Historic Photo Master
- Jan 2004
- Florida
- 38,619
- 78
- 1789
- 385
- 20674
- 5 Post(s)
The Speedmasters went on engines that were, most commonly, just one midsection length. Beginning in 1968 many different inline midsection length outboards became available in racing. (Simular to all the power & transmission options that suddenly became available then, for musclecars.) When the consumer 3.0 litre Mercury V-6 came to market in the 90's, the gearcases were immediately available with stubshafts and all different one-piece shafts. The need was there. All the large Mercury's since, Verado's included, are produced with the various shafts. The need is there. With the oldest Speedmaster's, there just wasn't any need.
05-16-2017, 01:58 PM #10
I didn't know the MC-1 would not work on a 15 inch mid? I almost bought one once to run under a 1500 short shaft. I guess it would not work? With that in mind, if I put the SSM adaptor on my SBP down the road will my normal 15 inch SSM's be too long? All stuff I have not got a chance to do yet.
L6fan57-88
05-16-2017, 02:08 PM #11
- Jan 2004
- Florida
- 38,619
- 78
- 1789
- 385
- 20674
- 5 Post(s)
05-16-2017, 02:38 PM #12
yes I haven't had to take my MC-1 apart so I cant say how close it is or isn't to other SSM driveshafts or even a standard driveshaft. have it on pretty good authority though that they were standard on the first Twister 1 Motor s in 1970. Cant speak to the length since the Twister 1 did use a BP mid but no clue about the thickness of the adapter used also.
05-16-2017, 03:17 PM #13
- Jan 2004
- Florida
- 38,619
- 78
- 1789
- 385
- 20674
- 5 Post(s)
I've got a yardstick, but as a rule, I don't use it...
Mark75H liked this post
3.0 Litre 20" Driveshaft/Exhaust Housing Question
By 1122 in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 4Last Post: 08-18-2015, 08:22 PM -
Mercury inlines
By 2us70 in forum Outboard and Racing HistoryReplies: 8Last Post: 05-29-2013, 10:34 AM -
inlines
By daytrader in forum Technical DiscussionReplies: 3Last Post: 09-28-2004, 09:12 PM -
omc driveshaft question
By charger19 in forum Technical DiscussionReplies: 4Last Post: 04-04-2003, 05:41 PM -
Inlines vs new 115 and 125's
By jnewtonsem in forum Technical DiscussionReplies: 9Last Post: 05-28-2002, 01:32 PM
