Results 76 to 80 of 80
05-03-2017, 08:28 AM #76
STRAIGHT 1/4 pipe tap. That boat being an 80 probably has already had a cable or two put in it.
05-03-2017, 04:36 PM #77
Dave Strong liked this post
05-03-2017, 07:05 PM #78
That's what I said.
I had a boat monday someone used a tapered tap on and I had to weld the hole closed for a do over.
05-03-2017, 07:15 PM #79
Couldn't remember the exact pitch, just know where the tap is in the tool box.
05-03-2017, 07:32 PM #80
Yeah, I got two of them
2001 225 Pro Max Neutral to idle speed RPMs
By L&BProMax in forum Technical DiscussionReplies: 6Last Post: 06-14-2013, 03:18 PM -
OMC Tech: might have found idle prob
By switzer 140 in forum Technical DiscussionReplies: 6Last Post: 07-30-2008, 06:39 PM -
High idle on my Yamaha Pro V after a good run...
By Boz in forum Technical DiscussionReplies: 4Last Post: 07-16-2007, 08:26 AM -
225x/shift prob
By ohio mike in forum Technical DiscussionReplies: 4Last Post: 04-03-2006, 08:57 AM -
2.0L Mercury Boggs,spits,coughs Midrange- High range good Idle good
By wpeterb in forum Technical DiscussionReplies: 2Last Post: 07-30-2004, 05:12 AM
