Results 1 to 15 of 24
    Jun 2004
    port st. lucie, fl
    Check out this barn find
  2. Likes powerabout, H20WKD, Capt.Insane-o liked this post
    Alpha ss, NICE
  4. Likes mrcrsr liked this post
  5. #3
    why is this here? seems like an advertisement . definitely not jet or v-drive.
    Jun 2004
    port st. lucie, fl
    Boatermike, where do you propose that I post this, in the outboard section? It is going on a friend's sweet 16 donzi, with a 4.3, that eventually will get a supercharger. Incidentally, I'm looking at changing the lower to a sportmaster, but have to figure out gear ratios. I haven't seen one in years and bought it for my buddy on the spot, thought it was cool. Boatermike, why don't you try becoming a team member and support the website?
  7. Likes specboatops, MeCapnDave liked this post
    Jun 2004
    port st. lucie, fl
ID:	374196. Here's what it's going on, I think the boat runs 52 currently
    Very nice find Charlie.
    We can add stern drive stuff here - there's no specific stern drive area on the site and this would be the closest thing to it I guess
    Given that, I added 'stern drives' as part of the group. If there is enough interest, I will add a separate stern drive section.
  10. Likes mrcrsr liked this post
  11. #7
    there should be a stern drive spot here.....................
  12. #8
    Jun 2004
    port st. lucie, fl
    Thanks Greg! Check this out, definitely started as a CLE lower, says vent but no vent screw presentClick image for larger version.
  13. #9
    Yes the ss is two inches shorter to raise x dimension and had cle lower, very cool piece
    very cool boat also
  15. Likes mrcrsr, H20WKD liked this post
  16. #11
    miami
    It's actually closer to 3"
    Attachment 374202
    what wou8ld be the normal rise of the raised x position? 4" higher?
  18. #13
    Jun 2004
    port st. lucie, fl
    Stern drive stuff typically puts the cavitation plate even or lower then the bottom of the hull. My guess is this thing will gain close to 5 mph at the speeds it runs. The pita is he has a gen2 transom assy so I'll have to do some mods get it to work.
  19. #14
    ok after google I see this is a trick question................sorry
  20. #15
    every boat I have ever had with a sterndrive was always mounted way to low. I would take the hole shot problems and the loose behavior just to have it go faster
  1. barn find
    By rock in forum General Boating Discussion
    Last Post: 04-09-2017, 01:19 PM
  2. Barn Find
    By vnemous in forum General Boating Discussion
    Last Post: 09-22-2015, 07:19 PM
  3. Barn Find
    By reeve025 in forum General Boating Discussion
    Last Post: 06-22-2012, 05:39 PM
  4. Barn find.
    By Smoking Joe in forum Outboard and Racing History
    Last Post: 12-16-2011, 03:55 PM
  5. barn find
    By 76youngblood in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 08-24-2009, 10:04 PM
