Results 61 to 75 of 80
04-27-2017, 06:13 AM #61
Member
- Mar 2017
- Canyon Lake, Texas
- 56
- 58
- 15
UPS ground is not as efficient as fedex ground, as I suspected. Stay tuned.... Expected to arrive today, but day is fairly full. Will let you guys know... Keeping my fingers crossed. But will still be checking timing next.
05-02-2017, 07:29 PM #62
Member
- Mar 2017
- 56
- 58
- 15
Carb is in...
Carb is back in. Took it out yesterday and initially had to raise idle to get 600-700. Held beautifully, ran like a champ and shifting issue is all but gone. With idle now rock-steady, I can see and feel that the linkage may need a tad of adjustment or more likely replacement. Or maybe the shift delay switch needs a little more stroking or replacement. only a couple times did it die, but felt like linkage had not fully and cleanly disengaged and thus hung up on the delay switch or something. But the level of incidence has dropped drastically. Have yet to check timing, will do that as soon as I can borrow a gun. But idle and wot are great. Rather than replace just the cable, think I'll put aside a fund for doing the whole control panel along with cables... but I am not sure if the new style will work at the back end. Seems quite a bit has changed back there. As I understand it, that shift delay switch is obsolete and no longer available.... Now you get to upgrade for an obscene amount of money to switch out a whole bunch of things. That's another topic, so i'll ask around with a new topic.
Thanks to all for your help and of course additional comments/suggestions more than welcome. - Doug
05-02-2017, 07:47 PM #63"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
CanyonDoug thanked for this post
05-02-2017, 07:49 PM #64
Replace the transom shift cable, if they stick even a little bit will cause the shift interupter to do crazy stuff. If you have the correct tap you can use the new style cable.
05-02-2017, 08:02 PM #65
05-02-2017, 09:35 PM #66
05-02-2017, 09:42 PM #67
Member
- Mar 2017
- 56
- 58
- 15
05-02-2017, 09:44 PM #68
Member
- Mar 2017
- 56
- 58
- 15
05-02-2017, 09:46 PM #69
Member
- Mar 2017
- 56
- 58
- 15
Dave Strong liked this post
05-02-2017, 09:51 PM #70
You found an interrupter switch for 1980. I thought they were no longer available. Unless you mean a setup to replace it with the more modern version.
05-02-2017, 10:13 PM #71
CanyonDoug liked this post
05-02-2017, 11:01 PM #721980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
05-03-2017, 05:37 AM #73
Member
- Mar 2017
- 56
- 58
- 15
05-03-2017, 05:41 AM #74
Member
- Mar 2017
- 56
- 58
- 15
05-03-2017, 06:18 AM #75
Mercury simply changed the way the cable goes in. The old style cable screwed in from the front of the housing and the new one screws in from the back making it easier to install. I think there is a service bulletin that shows how to do the mod.... very easy. If memory serves me right, it takes a 1/4" pipe tap.
2001 225 Pro Max Neutral to idle speed RPMs
By L&BProMax in forum Technical DiscussionReplies: 6Last Post: 06-14-2013, 03:18 PM -
OMC Tech: might have found idle prob
By switzer 140 in forum Technical DiscussionReplies: 6Last Post: 07-30-2008, 06:39 PM -
High idle on my Yamaha Pro V after a good run...
By Boz in forum Technical DiscussionReplies: 4Last Post: 07-16-2007, 08:26 AM -
225x/shift prob
By ohio mike in forum Technical DiscussionReplies: 4Last Post: 04-03-2006, 08:57 AM -
2.0L Mercury Boggs,spits,coughs Midrange- High range good Idle good
By wpeterb in forum Technical DiscussionReplies: 2Last Post: 07-30-2004, 05:12 AM
