Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 69
  1. #31
    Feb 2010
    massachusetts
    A couple more with the restored wheel and NOS rack and cable
  2. #32
    beauty
  3. #33
    Feb 2010
    massachusetts
    First time its seen the light of day this year , the motor is getting sent off to the machine shop this week for a tear down , inspection and mild rebuild .
  4. Likes whipper liked this post
  5. #34
    You did a great job on that boat.....
    Feb 2010
    massachusetts
    The good the not so good and the ugly . The good the crank will only need .010 under grind , the is just your original run of the mill 1970 455 that hasn't been taken apart and doesn't have any cracks yea ! The not so good is hole number three has some pitting from it sitting for so many years , the machinist thinks a .060 bore will remove them if not it will have to be sleeved and the block decked "cha ching" . The ugly , the heads are your run of the mill 2.00 intake nothing special heads that need a complete overhaul that have already been worked on as in knurled guides and they're warped to boot . I'm going to focus on getting the block done with new forged pistons (gonna try to get at least 9 to 1 ) , forged rods , a more aggressive cam and lifters . The next thing will be aluminum heads with 2.075 intakes the adjustable rockers . I'm kicking myself in the arse for selling my little 160 .
  7. #36
    super fine boat !
  8. #37
    Feb 2010
    massachusetts
    The engine parts are startin to trickle in , just got the forged H beam rods , timing gears and chain , the forged flat top pistons are on a truck somewhere on their way here . I had the machinist sleeve number three, that way im keeping the bore to .030 over , as soon as he gets the pistons he'll finish the boring and honing . I'm having him assemble a short block with oiling modification , crank and pistons then i'll finish it .
    Can i get a moderator to move this thread to the jet boat section , this part of my project doesn't really fit here . Thank you . Gil
  9. #38
    Sleeved and decked, what heads CCed? N crank good, stock rods worry you? Check the block number stamping what factory, doesn't matter? Looks good , oil work done, important. Right, California motor lol, had to go back and check.
  10. #39
    Feb 2010
    massachusetts
    The motor is going back together , the only parts that are original are the block and crank . I guess a mild freshin up went out the window .
  11. Likes FMP, Bodhi liked this post
  12. #40
    Girdle, cap straps just because? That's going to be one sweet boat! Maybe put up another boat pic, all I'm seeing is a pussy saying click here!
  13. #41
    Feb 2010
    massachusetts
  14. Likes Raysoncrafter liked this post
  15. #42
    going for best in show
  16. #43
    Your probably already on it, but port match the intake manifold to the heads, and the exh manifolds to the exh ports. Free 5+ hp. Looking good man.
    Run Joe Gibbs oil.
  18. #45
    Sep 2016
    McHenry,Illinois
    Damn fine job Gil! What did you use to clean the gunwhale moulding....looks nice a shiny. Glad to see some pics again! Mine's getting CLOSE!
  1. Is this a Glastron Carlson cvx-16?
    By CaryW in forum General Boating Discussion
    Last Post: 06-11-2011, 08:36 PM
