Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
    Sep 2015
    Twin Cities, Minnesota
    Removing Stubborn Melted Aluminum off of Chrome Cylinders
    Had a melt down last year. Is there some kind of slow painful way to remove this stubborn melted aluminum from my cylinders. Muriatic Acid works ok when the aluminum is really thin. Its in my exhaust and on the tops of the other two pistons.
    If you have a piston lying around, I could use one.
    Attached Thumbnails Attached Thumbnails 20170404_212823.jpg   20170404_212828.jpg   20170404_212834.jpg   20170404_212302.jpg
    TX......somewhere?
    in tha case of that one its called a "new sleeve".........
  3. Likes Capt.Insane-o, baja200merk liked this post
    Sep 2015
    I'm sure your right as usual. I just didn't want to have 5 chromes and one steel.
    TX......somewhere?
    there is a ton of 'em runnin' around..... can be fixed/new plate for $$$
    That focker is junk.
  7. Likes 1BadAction liked this post
    What caused it, a lean out?
    Sep 2015
    I have no liner in my midsection. This was prior to me owning it. I was just cruising along, motor was perfect and it just stopped dead like i shut the key off.
    A few weeks later I took off the CLE to make sure it didn't lock up instead, and I noticed that I couldn't see daylight through the lower unit. Ended up being the rubber liner gasket wasn't taken out of the midsection and it got lodged down low in the midsection right at the 90 degree turnout and completely blocked my exhaust system. I guess you can call it an extreme lean situation.
    Thats my theory anyways. and the welch plug is puffed upwards too.
    Wow, and the other five or even the other top one didn't burn . I guess their had to be a first one to hit the melting point. It happens fast enough to kill it and stay ahead of another melting. The others couldn't have been far behind .
    check for out of round.
    Jun 2001
    Cromwell. NEW ZEALAND
    Forget trying to remove the alloy. If you could get it off you would find the cylinder badly out of round.Been there many times with customer engines trying to save a chrome or nicasil bore just to find the bore egged. Bite the bullet and sleeve or replate.
    Popey
  13. Likes WillySteve liked this post
  14. #11
    Jun 2008
    Sardis Lake Oklahoma
    Spend the $900 and have 6 fresh cyls with plating, (USChrome),.....it's only money, why else do we mess with these things!!
  15. Likes FMP liked this post
  16. #12
    Jun 2012
    Indiana
    Replate job is more than 900. I have had a few done and i think they are approaching 1200 plus freight.
    Aug 2011
    ct
    $1140 plus ship
  18. #14
    Moline,Ill
    I don't know how the chrome bores work, but if that was nic it would need a sleeve
    is gone
  19. #15
    Jun 2008
    Quote Originally Posted by capteliminator View Post
    I just redid my Nic bores on my 260 6 Mos. ago!
    They don't use Nicasil anymore but something comparable an without digging up invoices I think the cost on the 6 cyls alone was right at 1100!
    hell....if yer gonna have to spend 900 then why not spend the 11.....I'm sorry I gave bad info!!!
    WillySteve Hendricks
    20XDC Bullet/Modified Merc 260
    295TF Charger/ProMax 225x-Sold!
    '83-20' Contender Pickle Fork/Merc 2.4 ModVP BridgePort EFI-Sold!
    '85-18' Stratus STV/Merc Hi-Po 2.4 EFI-Sold!
    Freedom 240 DLX Fisher Toon/Merc 115
    10' Cougar Cub/Merc 25HP On The Bottle!
    18" Home Made Tunnel/OS .021XM Outboard on 50% Nitro and Expansion Chamber
  1. Melted piston in Chrome bore. Now what?
    By Krazymaan in forum Technical Discussion
    Last Post: 09-11-2016, 10:14 PM
  2. Chrome Cylinders on 85 Mariner 150? HELP?
    By imthemedic in forum Technical Discussion
    Last Post: 12-18-2009, 12:40 PM
  3. Honing Our Chrome Bore Cylinders?
    By Glasply150 in forum Technical Discussion
    Last Post: 11-05-2005, 05:56 PM
