Results 1 to 15 of 25
Thread: How Best To Mix Gas and Oil
08-12-2003, 01:57 PM #1
Junior Member
- Jun 2003
- Toms River NJ/Cape Coral Fl
- 25
While fueling up, is it better to put the oil in the tank first and then fill with the appropriate number of gallons of gas or put the oil in last when you know exactly how much gas you've added??? If you put the oil in last, will it still mix thoroughly enough? Problem is I'm not sure of the accuracy of the fuel guages and don't want to put too much oil in first and then not be able to add enough gas>>
Thanks for any replies!!!
08-12-2003, 02:09 PM #2
I used to put oil in first, and if I couldn't put enough gas in for the oil, at least there was plenty of oil in there, and not the chance of it not mixing well enough!
Now I just take two 6 gal. cans to the store, and mix it for 6 gals.
If I need to completely fill up. I take 3 - 6 gal. cans.JOHN MASON
'83/VECTOR/MERC 200-- SOLD
'98 Quartershot T-3/ MERC 200
"If your not living on the edge, your taking up to much space"
08-12-2003, 02:15 PM #3
Junior Member
- Jun 2003
- 25
That seems to be the solution when you have small amounts of fuel to deal with..I have twin 60 gallon tanks, (I think, LOL, ) so until I'm sure about the quantities I'll have to be cafeful.. When I have the time I'll be toting 6 gallons cans from the local station.
Thanks !!!
08-12-2003, 02:53 PM #4
7000 RPM
- Central Florida
- 2,664
- 9
- 41
- 35
- 250
Get a funnel with a strainer and pour the oil into the funnel together with the gas.
08-12-2003, 03:05 PM #5
Junior Member
- Jun 2003
- 25
That also would be okay if I were dealing with limited amounts of gas. Remember I said I have twin 60 gallon tanks. I'll probably, for starters, use a gallon of oil and then add 32 gallons of gas on each side. This should keep me going for awhile..
08-12-2003, 03:22 PM #6
7000 RPM
- Central Florida
- 2,664
- 9
- 41
- 35
- 250
A good funnel will take the gas PDQ and depending on where you buy gas, a strainer in the bottom can make it worth the small effort. Plus you don't spill any oil on the deck trying to hit the fill hole
I don't remember where I got mine but something like these from Jaz will work nicely.
http://www.jazproducts.com/funnel.htm
08-12-2003, 03:33 PM #7
i found an acurate way is to out in 6 gallons and add a 1/2 quart of oil, then aonther 6 and so on, or you can do it with 12 gallons too.
Drive it like you stole it!!, And if you did steal it, drive faster!!
08-12-2003, 04:18 PM #8
I've always added oil after the gas and don't think there's a problem. The only downside is that you've got to be sure you leave enough room to get the oil in.
08-12-2003, 04:44 PM #9
Get you one of these!!! I got mine at Academy Sports.
http://www.basspro-shops.com/servlet...rTarget=browseLast edited by CDave; 08-12-2003 at 04:46 PM.
93 STV Mod VP/MERC 2.5 200
Proverbs 4:18-20
-- John F. Kennedy 1962
08-12-2003, 06:41 PM #10
BC1
I've got twin 60 tanks and the funnel works just great. Just poor oil and gas at the same time. I mix 1 quart to 12.5 galloons and so on until the tanks are full. No problem!!
Just Duck'n Around
08-13-2003, 07:29 AM #11
Junior Member
- Jun 2003
- 25
Thanks Barry for your advice!!
08-13-2003, 07:31 AM #12
Junior Member
- Jun 2003
- 25
yamahadog,
I appreciate your input.. By the way, during the winter, I'm in Cape Coral>>
08-13-2003, 07:34 AM #13
Junior Member
- Jun 2003
- 25
Raceman, CDave, and Thunderduck,
Thanks for the help. I'll try different methods to see what works best for my situation!!!
08-13-2003, 08:57 AM #14
OIL mixing Method
I clean out used 20 oz. plastic Coke bottles and fill them with oil for the ratio I want to run. Each bottle holds enough for 5 gallons of fuel. Pump in 5 gallons of fuel - add one bottle of oil - repeat until full.
The oil mixes with the fuel this way very easily.
50:1 - 13 oz. per bottle
40:1 - 16 oz.
32:1 - 20 oz.
It may not be the BEST way, but it works for me. I hope this helps.Disclaimer: Everything I post is just my .02, and should be take only as opinion. These opinions tend to be notoriously WRONG, and any that are correct, can only be attributed to my being dropped on my head as a small child - repeatedly.
08-13-2003, 09:05 AM #15
Junior Member
- Jun 2003
- 25
Another excellant idea.. In fact, I just did similar with 1 quart oil containers that have the markings down the side. Filled a bunch with 24 ounches to mix with each 6 gallons of gas.. I think I'm good to go!! *(fast)
