Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
    Aug 2016
    Southwest Mi
    Mercury 90hp. Or Yamaha 90hp. 2-Stroke ? Pros / Cons
    Looking to upgrade to a 90hp.
    Looking at:
    1987-1997
    Mercury 90hp.
    Weight 265 Lbs.?
    1984-1995
    Yamaha 90hp.
    Weight 223 Lbs.?
    Both are Re-man's, currently rigged with Yamaha
    Which has been great and I have nothing against
    It or know much about. (Came with boat)
    Just always been a Mercury fan.
    So if I were to upgrade in power now
    Would also be the time to re-brand.
    So for the big picture, I would like to know
    The pros and cons of both.
    Parts availability of both long term.
    Etc.etc. etc.
    Look forward to your thoughts
    Yamaha
    8 Post(s)
    Yamaha
    Aug 2016
    Southwest Mi
    Seeing a trend???
    Y... I've seen the same motor since it was new and it's still showing off.
    Jul 2001
    Paris, France
    Hard to beat a 3cyl Yamaha.
    ARGO Cat 18'
    Mercury 2.4EFI/CLE
    If it's not a cat it's a.............dog ?
    South Africa
    If you are going to run it standard then the Merc, but must be the later style with the drop on cowl.
    Lots of low down grunt, great economy, hold its head against the Yamaha in just about all conditions
    If you are going to run it hard or fast or want to do modifications then go for the Yamaha
    Aug 2016
    Southwest Mi
    Quote Originally Posted by Wayne Cammidge View Post
    Any particular year you like for the ( Yamaha 90 hp. 2 Stroke )?
    Any mods you like for a nice warm up, not a maintenance nightmare?
    One item I would like to do right away is have the midsection
    modified to a 15"
    May 2007
    Pierre Part La.
    I am a Yamaha man 100%,
    But, If the hull is heavy and or will be loaded most times, one thing to consider is the Merc has quite a few more cubes and a lower gear.
    If that's not the case, medium to light hull, not carrying a huge load. The Yammi is flawless. If you have any intention of tinkering, only Yamaha. To shorten the mid is no biggie.
    11-20 -08 1980 14' Allison
    2018 Carbon Fiber 15' Allison
    homemade 15" 90 Yamaha
    nice and quick 7900 rpm
    Happiest driver on the board. Chris Carlson reeds are the way to go. CCM
    http://www.youtube.com/watch?v=KQyBn...er_profilepage
    Aug 2016
    Southwest Mi
    Quote Originally Posted by Jason Johnson View Post
    My hull is 940 Lbs. As is, Rigged with fuel.
    with the current 70 hp. It does 40 mph with
    my wife and I.
    Thoughts were, 90hp. 15" mid.
    Low water pickup if possible and
    Set a better (x) dimension.
    Possibly warm it up, but still a daily
    Little hot rod, not a maintenance nightmare.
    Defiantly the Yammie.
  12. #12
    South Africa
    Definitely the Yammie.
    It will fly on that setup.
  13. #13
    Aug 2012
    MI
    Cougarman, I think it's unanimous for the Yamaha on that boat.
    SW Michigan here also, what lakes do you run that boat on?
  14. #14
    Jun 2013
    Venezuela
    Yamaha no doubt. Those little motors will outlive us all
  15. #15
    Aug 2016
    Southwest Mi
    Quote Originally Posted by cyhuff View Post
    Place we like to Frequent... No Particular order.
    South Haven
    Saugatuck
    Holland
    Muskegon
    West Michigan has beautiful beaches and lots of water!
  1. short shaft 90hp yamaha 2 stroke?
    By fastleeboat in forum Technical Discussion
    Last Post: 07-25-2014, 09:20 AM
  2. 2003 90hp YAMAHA four stroke.?
    By dagodiver in forum General Boating Discussion
    Last Post: 07-17-2014, 02:53 PM
  3. Yamaha 90hp vs Mercury 90hp
    By twright55 in forum Technical Discussion
    Last Post: 06-13-2010, 07:08 AM
  4. 2002 Mercury 90hp 4 stroke
    By blkmtrfan in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 04-29-2008, 07:39 PM
