Results 1 to 15 of 35
04-02-2017, 02:49 PM #1
Member
- Aug 2016
- Southwest Mi
- 75
- 16
- 18
Mercury 90hp. Or Yamaha 90hp. 2-Stroke ? Pros / Cons
Looking to upgrade to a 90hp.
Looking at:
1987-1997
Mercury 90hp.
Weight 265 Lbs.?
1984-1995
Yamaha 90hp.
Weight 223 Lbs.?
Both are Re-man's, currently rigged with Yamaha
Which has been great and I have nothing against
It or know much about. (Came with boat)
Just always been a Mercury fan.
So if I were to upgrade in power now
Would also be the time to re-brand.
So for the big picture, I would like to know
The pros and cons of both.
Parts availability of both long term.
Etc.etc. etc.
Look forward to your thoughts
04-02-2017, 03:28 PM #2
Yamaha
04-02-2017, 05:40 PM #3
5000 RPM
- Oct 2011
- Ontario
- 427
- 47
- 54
- 547
- 159
- 8 Post(s)
Yamaha
04-02-2017, 05:45 PM #4
Member
- Aug 2016
- Southwest Mi
- 75
- 16
- 18
Seeing a trend???
04-02-2017, 06:29 PM #5
Screaming And Flying!
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
Y... I've seen the same motor since it was new and it's still showing off.
04-03-2017, 04:02 AM #6
Hard to beat a 3cyl Yamaha.
ARGO Cat 18'
Mercury 2.4EFI/CLE
If it's not a cat it's a.............dog ?
04-03-2017, 07:15 AM #7
5000 RPM
- South Africa
- 583
- 9
- 35
If you are going to run it standard then the Merc, but must be the later style with the drop on cowl.
Lots of low down grunt, great economy, hold its head against the Yamaha in just about all conditions
If you are going to run it hard or fast or want to do modifications then go for the Yamaha
04-03-2017, 08:37 AM #8
Member
- Aug 2016
- Southwest Mi
- 75
- 16
- 18
04-03-2017, 03:25 PM #9
I am a Yamaha man 100%,
But, If the hull is heavy and or will be loaded most times, one thing to consider is the Merc has quite a few more cubes and a lower gear.
If that's not the case, medium to light hull, not carrying a huge load. The Yammi is flawless. If you have any intention of tinkering, only Yamaha. To shorten the mid is no biggie.11-20 -08 1980 14' Allison
2018 Carbon Fiber 15' Allison
homemade 15" 90 Yamaha
nice and quick 7900 rpm
Happiest driver on the board. Chris Carlson reeds are the way to go. CCM
http://www.youtube.com/watch?v=KQyBn...er_profilepage
04-03-2017, 09:05 PM #10
Member
- Aug 2016
- Southwest Mi
- 75
- 16
- 18
My hull is 940 Lbs. As is, Rigged with fuel.
with the current 70 hp. It does 40 mph with
my wife and I.
Thoughts were, 90hp. 15" mid.
Low water pickup if possible and
Set a better (x) dimension.
Possibly warm it up, but still a daily
Little hot rod, not a maintenance nightmare.
04-03-2017, 10:00 PM #11
Defiantly the Yammie.
04-04-2017, 01:08 AM #12
5000 RPM
- South Africa
- 583
- 9
- 35
Definitely the Yammie.
It will fly on that setup.
04-04-2017, 04:37 AM #13
Cougarman, I think it's unanimous for the Yamaha on that boat.
SW Michigan here also, what lakes do you run that boat on?
04-04-2017, 09:07 AM #14
5000 RPM
- Jun 2013
- Venezuela
- 186
- 13
Yamaha no doubt. Those little motors will outlive us all
04-04-2017, 02:29 PM #15
Member
- Aug 2016
- Southwest Mi
- 75
- 16
- 18
short shaft 90hp yamaha 2 stroke?
By fastleeboat in forum Technical DiscussionReplies: 5Last Post: 07-25-2014, 09:20 AM -
2003 90hp YAMAHA four stroke.?
By dagodiver in forum General Boating DiscussionReplies: 4Last Post: 07-17-2014, 02:53 PM -
Yamaha 90hp vs Mercury 90hp
By twright55 in forum Technical DiscussionReplies: 9Last Post: 06-13-2010, 07:08 AM -
2002 Mercury 90hp 4 stroke
By blkmtrfan in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 4Last Post: 04-29-2008, 07:39 PM
