Results 1 to 15 of 26
Thread: Dual cable vs hydraulic
03-20-2017, 08:43 PM #1
5000 RPM
- Jul 2014
- Mississippi
- 196
- 18
I'm getting close to finishing up my Hydrostream Vector. I have a dual cable steering setup now but I was thinking about a hydraulic. I noticed that they have a Baystar kit for around $500 and about double that for the Seastar. I'm only going to be running a 2.5 liter 150hp on this boat, would the Baystar work or should I just keep the dual cable system that I already have?
03-20-2017, 09:08 PM #2
DO NOT GO FOR BAYSTAR
its cheap crap with crap seals, its absolutely dangerous, and has been the killer of a few people.
None of the cheap stuff is worth even thinking about.
and no it NOT made in the usa, its far eastern Chinese crap with a sticker on it.
The seastar might look the same to some people but its totally different quality.
get a good used one in preference to cheap nasty dangerous crap, then go to a hydraulics shop and buy new seals and hoses.
been far too many people killed with the cheapo stuff, the seals on the cheap crap are just waiting to go bad, and when they do the
boat turns faster than you could turn a tiller motor.
just my opinion after looking into how a few people over here got killed in brand new boats with cheap hydraulic steering.
It has happened a lot world wide.
never skimp on the steering, especially with hydraulic stuff.
03-20-2017, 09:14 PM #3
Are your cables opposed,or same side? If your lucky enough that they are opposed,and they are in good condition,just spend a little time to get them adjusted properly and keep em.JMO
03-20-2017, 09:16 PM #4
5000 RPM
- Jul 2014
- Mississippi
- 196
- 18
I've always felt safe with a dual cable system, how do you feel they compare to the Seastar ?
03-20-2017, 10:04 PM #5
03-20-2017, 10:10 PM #6
5000 RPM
- Jul 2014
- Mississippi
- 196
- 18
Mine are on the same side , parallel to each other
03-20-2017, 10:48 PM #7
Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,333
- 1065
- 412
- 4725
- 2174
- 9 Post(s)
How about add electric assist column?
Get to keep real feel without the load
Guys are using it in tunnel boats from sst45 to f1
Ps and solid mounts
03-21-2017, 11:45 AM #8
Member
- Oct 2007
- 88
- 10
- 31
- 48
seastar
I love the seastar on my twin inline set-up. Twin inline 1350s on a 17 Switzer. No torque and the wheel doesn't try to spin out of my hands.
1964 Chris Craft Holiday
Homemade Glen-l Crackerbox
71 Switzer 17 with twin Merc 1350s
W2F a V-King liked this post
03-21-2017, 02:24 PM #9
You still have the safety of two cables,that's good. The down side is in order to preload the pinion, one cable is in tension and the other is in compression,VS opposed, where both are in tension witch makes for a smoother and slightly more ridged setup.I guess the hydraulic is the way to go.I just grew up with the dual ride guide and its never failed me.And to spend north of eight bones to try,just not in the cards for me.
03-21-2017, 03:45 PM #10
5000 RPM
- Sep 2006
- 472
- 166
- 9
- 43
- 51
Can a parallel setup be changed to a opposite set-up?
But keep the steering helm and one of the 2 cables and just get a longer one(boat is offset not center steer).Last edited by coffeeguy; 03-21-2017 at 03:46 PM. Reason: Ask more
03-21-2017, 04:04 PM #11
SEASTAR IS PERFECT. THAT IS QUALITY STUFF,
its the baystar cheap crap thats bad.
there is a very good reason that it is so much more expensive, its made better.
those two old mercs sitting side by side keeping each other company look very nice, something about those old inlines.
03-21-2017, 04:27 PM #12
Going from dual to hydraulic is an upgrade that will make you glad you spent the money. When I first put it on my Allison I thought I ruined my boat but the more I drive it the better I like it. No real feedback and it takes a few trips to get used to the different feel. I have had dual parallel and opposed, string, and hydraulic. My favorite is string but only in a race boat and next is definitely hydraulic. It is kinda pricey but if it's in the budget you will never look back.
RockTeam Junk
gary slagle liked this post
03-21-2017, 09:47 PM #13
coffeeguy thanked for this post
03-22-2017, 09:13 AM #14
Opposed is much safer than the cables being on the same side. With dual or single cable you only have ONE bolt holding the steering arm to the mid, if it snaps you have no steering...I know, it happened to me and I got chucked out of the boat. With the opposed attachment kit on the engine you would have to have THREE bolts all fail at the same time to completely loose your steering, very unlikely. I don't know what hydraulic steering feels like in a small v-bottom but in my STV I can let go of the wheel at 80mph!
03-22-2017, 11:21 AM #15
keep your dual set up and #8 tiller bolt! i bought my s star a piece at a time on e bay found a new pro helm 350 cylinder good used 225 the fluid is the biggest rip-off of all i had serious torque issues jacked up high only reason went hydraulic my right shoulder was hurtin holdin that sucker straight my family cc has sea str its a dream to steer at 40 mph. sorry left shoulder!
Dual cable to hydraulic steering
By dockrash in forum Props, Setup, and RiggingReplies: 15Last Post: 02-03-2015, 05:50 PM -
hydraulic vs dual opposing cable steering
By wanagofass in forum Technical DiscussionReplies: 29Last Post: 12-15-2010, 03:25 PM -
hydraulic or dual cable for ss 2000
By i2zh2o in forum Technical DiscussionReplies: 3Last Post: 05-09-2004, 01:09 PM -
hydraulic or dual cable ??
By inspectorlance in forum General Boating DiscussionReplies: 15Last Post: 07-25-2003, 12:55 AM -
dual cable or hydraulic???
By xstream in forum Props, Setup, and RiggingReplies: 19Last Post: 03-06-2003, 10:10 PM
