Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 16 to 30 of 81
    take the starter off and clean it out.
    or you do the most stupid thing ever and try rope starting it !!!!! only joking forget that ha ha it definitely wont happen.
    I would clean up the starter internals. check the brushes etc. only takes 20 mins to get it off and apart.
    I dont know about over there but those starters are very expensive.
    if its shot just take it to a car/truck starter repairs, be about half the cost of a marine repairs..
    considering how crap starter motors are built they realy are a rip off.
  2. #17
    Ft. Lauderdale, Fl
    Quote Originally Posted by phillnjack View Post
    He said it's a new arco starter
  3. #18
    Mar 2017
    Southern Indiana
    Thanks again. I'm kind of leaning towards it being internal. I may crack the engine open and make sure all the bearings are turning freely.
  4. #19
    Mar 2017
    Southern Indiana
    I think I got burned. I guess you can't trust some people's word.
  5. #20
    Pickering and Lakefield, Ontario, Canada
    If you haven't changed out the cables then why would you think its internal? You say it spins OK without the plugs in.
  6. #21
    Mar 2017
    Southern Indiana
    Quote Originally Posted by 58Evinrude View Post
    I ran jumper cables from the battery directly to the starter. It wasn't any faster than cranking it with the key.
  7. #22
    Do whatever makes ya happy. But if if it cranks over okay without the plugs in, and spins over by hand, I don't think its a bearing problem. But I'm not there and can't see what you're seeing. Good Luck, let us know what you find.
  8. #23
    Mar 2017
    Southern Indiana
  9. #24
    Mar 2017
    Southern Indiana
    I appreciate the help. I will make new cables before tearing into the motor.
  10. #25
    Jumpers are ok going from battery to battery, but for carrying the load to a starter they aren't the best, just cause they aren't bolted at the connections.
  11. #26
    Mar 2017
    Southern Indiana
  12. #27
    Mar 2017
    Southern Indiana
    I see. That makes sense.
  13. #28
    Ft. Lauderdale, Fl
    If you take the plugs out and put a socket and ratchet on the flywheel nut, You should be able to spin it with two fingers; the only resistance will be the water pump. If there is so much resistance that you have to use two hands, drop the lower unit and try again. If the strong resistance goes away, you got a bad gear case, if it stays, it's the engine.
    If there is little resistance (two fingers only) then it's electrical...... battery cables, battery switch, starter solenoid, battery.......
  14. Likes DanUmbarger liked this post
  15. #29
    Ft. Lauderdale, Fl
    Back to your original question on end play. The engine should have no end play. There is a ball bearing at the bottom of the crank that is held in secure in the block...... no movement. Now, If you have side play at the flywheel end, you got a problem.
  16. #30
    What he says
  1. 260 cranking roblem
    By 20cc in forum Technical Discussion
    Last Post: 05-15-2012, 06:06 PM
  2. Cranking in Gear
    By Beastbullet in forum Props, Setup, and Rigging
    Last Post: 12-19-2009, 09:22 AM
  3. 225 Pro Max Cranking Problem
    By jay j in forum Technical Discussion
    Last Post: 06-02-2005, 06:15 PM
  4. cranking problem with 2.4
    By northeastcat in forum Technical Discussion
    Last Post: 07-28-2004, 11:20 AM
  5. Cranking PSI??
    By jjmalkow in forum Technical Discussion
    Last Post: 03-09-2003, 05:44 PM
