Results 1 to 15 of 18
    May 2016
    keys
    Allison SS 2000 as a daily driver
    Keep having a thought of turning my SS into a daily driver vehicle. I live and work on the water about 25 miles apart. Currently the boat has a 200 EFI with 15 mid and bobs case.
    A friend just repowered his flats boat with a new 115xs. This got my wheels turning towards newer power and a setup geared toward efficiency and reliability.
    Questions would be what lower units could be run on the new 115xs, would a sportmaster fit? What other new engines might work better for top efficiency? What case would remain intact long term running surfaced.
    Goals, be able to run over 80mph top end. Max efficiency in cruise speed. Daily saltwater use.
    How would you set it up, and why. Thanks
    May 2002
    Harriman, TN
    I would go with the 175 Pro Xs. You can put a sporty on it too. It would be the best of both worlds. I have been thinking about getting rid of my 225x and doing that since I hope to be running the boat a lot more now that I am in TN.
    Prince George B.C. Canada
    That would be a cool setup with a 175xs. Talk about a gas sipper yet still high high performance.
    May 2016
    keys
    I thought 115 after reading old post and articles where the SS tested 13mpg with the 115 fict evenrude years ago.
    I like that a 175 would still be 2 stroke vs the 115 4joke, just not sure it's far enough into the fuel efficiency range I'd like to see. A durably case like a sporty is a big factor as well. Think I'll swing by my Merc dealer today.
  5. Likes FMP liked this post
    May 2016
    keys
    As a bonus a low HP engine might actually make it insurable!
    I know a friends bullet regularly gets 10mpg with a 150 ficht. 200 etec is a bit less but faster.
    Mar 2010
    houston, tx
    200 ROS
    my Allison would stab me in the dark when I was sleeping if I put a 20" 115 on it.
  9. Thanks RIVERRUMMER 70 thanked for this post
    Sep 2014
    Iowa
    I would go with 175pro xs. There is an xb2002 with a 175proxs running 90 with a sportmaster on it. The boat would run 90 easy, wouldn't be surprised to see 10mpg, and you can get a brand new one for 1/2 the cost of a 200ROS.
    Mar 2010
    houston, tx
    Quote Originally Posted by JCSmile View Post
    Ss2000's don't deserve to have ho hum 20"'motors hung on them. What did they ever do to you to deserve that LOL!
    Sep 2014
    Iowa
    Quote Originally Posted by 90 5.0 View Post
    Can't say I disagree with you there. That being said, there's something about buzzing Baja's with a 115 on the back. My dad had an SS with a 115 faststrike that ran 83 and later put a 150 promax on and it ran 97, so there's something to be said for small power on an efficient boat. One of his favorite stories of the late 90's a couple guys bought brand new baja hammers and he passed them both while grinning and pointing back at a 115.
    May 2016
    keys
    I knew there would be those that hate the idea. I'm gonna keep my 15 inch motor on the shelf for later on, just need economical reliable daily driver now.
    I stopped in to my local Merc dealer and explained what I'm after, waiting for a response.
    Think any of the 150+ HP options aren't going to get me to fuel efficiency numbers, there really just overweight underpowered clumsy 20 inch versions of what I already have. 6 is way too many cylinders for anything less than 200hp.
    I would look at etech if I thought the case would live, and the dealer's didn't seem to like the idea of solid mounts either.
    Really sad how little outboard technology has advanced since the 70's , 50 years of shoving a giant brick shaped club foot lower unit thru the water.
  14. #12
    Sep 2014
    Iowa
    Quote Originally Posted by Whaaaaat View Post
    Maybe you already stated, but what are you looking for mpg's at 50-60mph? No matter what you get, I think either a sportmaster conversion or coning the lower is going to help get the case out of the water at get the boat up on the pad so you can see the fuel efficiency you are looking for. I know Allison has had a 150 Honda and SS on their website for years with claims of 12 mpg. I guess I don't know for sure, but I think you are going to want something in the 150hp range for best fuel economy. I think the 115 might be lacking just a little bit on the torque side of things and be under a lot more of a load at cruising speeds.
  15. #13
    May 2016
    keys
    From what I've read on Allison's site, here and Internet. The boat was tested with 115 fict engine I believe, fuel at cruise was over 12mpg
    The Honda your thinking of was a 90hp not a 150. I believe the problems with trying to make the Honda gearcase run surfaced was too large a hurdle to keep testing.
    As for fuel efficiency at cruise, I would like anything over 13mpg. And would really like to do it all with a full warranty, at least from the lower up.
  16. #14
    Moline,Ill
    It seems like I remember a v4 Yamaha in the mix somewhere, maybe the grand sport, or am I just nuts? ��
    is gone
  17. #15
    Feb 2007
    lily lake WI
    I would put a 175 xs on it 5 year warranty and it uses very little gas plus would still push that boat 75-85 all day new they are $11,000-12,500
  1. What is your daily driver?
    By Scream And Fly in forum The Scream And Fly Lounge
    Last Post: 12-23-2003, 06:36 PM
  2. Daily Driver
    By Checkmate Too in forum The Scream And Fly Lounge
    Last Post: 01-17-2003, 07:15 AM
