Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
    If the boat runs good on a portable tank, then it would indicate a problem with the built in tank. Thousands of these boats have been run for years w/o an electric pump. I would investigate the pick up and hoses again before I ran an electric pump for no real valid reason. 15' is no problem with 3/8'' fuel line and fittings. jm2cts
  2. Likes W2F a V-King liked this post
  3. #17
    Dec 2012
    tn
    Remove anti siphon valve, throw it as far as you can (be careful not to hit anyone), reconnect fuel line.
    Picture is worth 1000 words- this is anti-siphon I removed
  4. Likes W2F a V-King liked this post
  5. #18
    There's the culprit. Thank the know it all's from the BIA and feds for requiring that POS.
  6. Likes skeeter91 liked this post
  7. #19
    Dec 2012
    tn
    Yep - that was it- Took it to full throttle and held it there with out issue-
  8. Likes W2F a V-King liked this post
  9. #20
    Every experienced boat owner on here has fought with those things before, it just comes with the territory. Keep in mind that since it was removed, if the end of the fuel hose goes lower than the gas level it WILL siphon the fuel out of the tank. When you modify these kind of nanny safety features, you become the safety officer.....
    Dec 2012
    tn
    This something like my 20th boat to own and I never had an issue with it before- never had a 15' gas line either- if the hose gets below the tank on this tank - then the boat will be upside down ):
  11. Likes XstreamVking liked this post
  1. 2.5 merc runs poor
    By blackmax mark in forum General Boating Discussion
    Last Post: 09-20-2016, 11:02 PM
  2. Mercury Tech: 1980 Merc 2.4 runs on 4 or 5 cyl cold, runs on all 6 warm
    By mklein in forum Technical Discussion
    Last Post: 07-06-2016, 01:53 PM
  3. engine runs almost perfect but need help tweaking carb
    By ummagumma in forum Technical Discussion
    Last Post: 07-08-2014, 10:21 PM
  4. Replies: 2
    Last Post: 02-19-2012, 08:59 AM
  5. Mercury Tech: 2.4 (carb) Merc runs out of gas
    By Surface Scratcher in forum Technical Discussion
    Last Post: 09-19-2010, 04:46 PM
