Results 16 to 21 of 21
02-27-2017, 04:33 PM #16
Screaming And Flying!
- 15,058
- 407
- 1450
- 6006
- 11665
If the boat runs good on a portable tank, then it would indicate a problem with the built in tank. Thousands of these boats have been run for years w/o an electric pump. I would investigate the pick up and hoses again before I ran an electric pump for no real valid reason. 15' is no problem with 3/8'' fuel line and fittings. jm2cts
W2F a V-King liked this post
02-28-2017, 07:24 AM #17
5000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
02-28-2017, 07:29 AM #18
- 15,058
- 407
- 1450
- 6006
- 11665
There's the culprit. Thank the know it all's from the BIA and feds for requiring that POS.
skeeter91 liked this post
03-06-2017, 02:37 PM #19
5000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
03-06-2017, 03:11 PM #20
- 15,058
- 407
- 1450
- 6006
- 11665
Every experienced boat owner on here has fought with those things before, it just comes with the territory. Keep in mind that since it was removed, if the end of the fuel hose goes lower than the gas level it WILL siphon the fuel out of the tank. When you modify these kind of nanny safety features, you become the safety officer.....
03-06-2017, 03:17 PM #21
5000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
XstreamVking liked this post
2.5 merc runs poor
By blackmax mark in forum General Boating DiscussionReplies: 0Last Post: 09-20-2016, 11:02 PM -
Mercury Tech: 1980 Merc 2.4 runs on 4 or 5 cyl cold, runs on all 6 warm
By mklein in forum Technical DiscussionReplies: 2Last Post: 07-06-2016, 01:53 PM -
engine runs almost perfect but need help tweaking carb
By ummagumma in forum Technical DiscussionReplies: 22Last Post: 07-08-2014, 10:21 PM -
Bought 1997 Merc OS Carb 225 3.0, and parts motor EFI..Can I use efi on carb engine
By Zoomba in forum Technical DiscussionReplies: 2Last Post: 02-19-2012, 08:59 AM -
Mercury Tech: 2.4 (carb) Merc runs out of gas
By Surface Scratcher in forum Technical DiscussionReplies: 5Last Post: 09-19-2010, 04:46 PM
