Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 69
    Feb 2010
    massachusetts
    Quote Originally Posted by HST Madman View Post
    Gil, love to see your finished boat if it is done by next summer out on Lake Winnisquam in Laconia NH. I boat there often in my Hydrostream Virage - it is about 7 miles long by 1 mile wide and never too crowded or nearly as rough as Lake Winnipesaukee gets. Beautiful new double wide and free launch ramp as well. Very sweet setup and lots of free parking as well.
    I'm hoping to get her finished for next season so i can hit the lakes up there , looks like the sand bar at Winnisquam gets pretty busy during the summer , looks like a good time there .
  2. #17
    Feb 2010
    massachusetts
    What is your plan for pump and power, Big Olds/Berkeley ?
    I'm going to run the 455 Olds with a JC pump for now . If i can get anywhere near 55-60 mph with it I'll be happy . If the Olds grenades its self I'll probably go to a BBC .
  3. #18
    What year Olds, stock crank, N casting are strong, rods are strong, what letter head, if you need extra strenght Mondello in CA has lots of options from caps to girdles etc. You shouldn't have any problem with a 455 if you set it up right. Easy to make 500 hp and loads of torque with stock big valve heads and porting and good cam choice with intake and have it live for years. Not sure about that pump.
  4. #19
    Feb 2010
    massachusetts
    Its a 70 455 from the Fremont CA plant , from what i learned tracing the serial numbers back it more than likely came from a 442 . I havent broken it down yet but it has "E" heads and if my research was good it should have the nodular crank in it . I'll have a better idea after i tear it down . If its internals are good i'm going to leave it alone aside from a few oiling modifications and new seals . This boat is just too big to expect big MPH numbers from a 350 to 400 hp Olds . To break upper 60's to 70 i'm gonna need 500 to 600 hp and while i can get that out of the Olds with a whole lot of money I could do the same with a bbc for a lot less money .
  5. #20
    Nov 2003
    Bangkok, Thailand
    Gil, yeah sandbar at Winnisquam gets fairly crowed by the bridge but plenty of space usually to anchor your boat. There is a smaller sandbar over by where the new launch ramp is and my wife and I go there often when main sandbar gets to crowded. Great clean clear water lake and I do not miss the madness over at Winnipesaukee at all. You would love it I think - your boat is the perfect size and will probably be the only boat with a jet pump drive. Mine is the only Hydrostream I have seen to date Take care. Jim
  6. #21
    Feb 2010
    massachusetts
    Got a few more things done today . I'm pretty sure it will float now lol .
  7. Likes XstreamVking liked this post
  8. #22
    South Carolina
    Any new pictures to show?
  9. #23
    Nov 2003
    Bangkok, Thailand
ID:	341541Gil_CV21, you ready yet to bring your boat to Lake Winnisquam in NH? Where does your project stand? I think my first run of season will be end of next month - can't wait to run her wide open.
  10. #24
    Feb 2010
    massachusetts
    Its startin to look like CV21 , just have to polish the top rail and install .
  11. Thanks Capt.Insane-o thanked for this post
    Likes Capt.Insane-o, FMP, Greenboat liked this post
  12. #25
    Nov 2003
    Bangkok, Thailand
    Very nice Gil_CV21 Will 2017 be your debut in Lakes Region of NH? Would love to see it in person. Good luck with the finished product!! My Hydrostream Virage going into winter storage tomorrow until April 2017
    HST Madman.Click image for larger version.
  13. #26
    Looking good. What happened with the olds, did you get into it? As I said before, porting those heads which should be big valve heads and a good cam, intake that's worked and matched and 850+ holley will get you all the power that pump will take. That e head or big valve c head motor with a quadra jet did 500 torque and 370- 400 HP depending on the cam option and car it was in.The F heads are most looked for but a properly ported c or e will get it done, at this point in time F heads are left stock for restorations. The Toro GT was rated at 400 HP, the B07 Delta about 390 HP so bit of work and you are in the range with stock rods and pistons. Cost wise a BBC will still need work to get those numbers unless you have a big c i tall deck.
  14. #27
    Feb 2010
    massachusetts
    That olds has some teeth thats for sure , mine is still sittin waiting its turn , pretty soon its off to the machine shop .
  16. #29
    At about the 1:48 mark, he gives it some revs. Had to turn on the speakers and turn it up. Really good sound.
  17. #30
    Feb 2010
    massachusetts
    The dash has new burlwood vinyl, i mounted the dash and gauges and the steering wheel and rack & cable are going in next .
  1. Is this a Glastron Carlson cvx-16?
    By CaryW in forum General Boating Discussion
    Last Post: 06-11-2011, 08:36 PM
