Page 3 of 3 FirstFirst 1 2 3
Results 31 to 35 of 35
  1. #31
    Jan 2008
    eatonton ga
    Quote Originally Posted by W2F a V-King View Post
    Ouch!! What do you think caused that?
    Loose nut behind the wheel and on the gear case lol!!!
    good eye bob
    19 bullet
    82 v king
    84 v king
    93 stv pro comp
    07 venom
    80 gt20
    93 v-21
    89 stv procomp
    97 xr 2001
    89 stv pro comp
    82 17 action marine
    99 action craft flats boat
    88 xr2002
    90 Stv pro comp
    10 mirage 1/4 master
    98 mirage 1/4master
  2. #32
    May 2011
    Charlotte, NC
Name:	2017-02-07 11.51.441.jpg
    Hi James. As you can see in this picture, the lower unit had a loose bolt up under the tab (notice the air gap between mid and lower). I had problems with this about three years ago, but without other damage. At that time, we replaced the bolt with one size larger and re-threaded the mid to accept that bolt.
    I guess the oversize bolt eventually worked loose (as it did previously with the original bolt), and then downward forces from romping the .... out of it caused a pivot point at the front two mounting studs.
    Pivot point worked the aluminum casting up and down causing cracking, which continued to propagate until it was completely cracked all the way through. Which means, I have been running a broken mid section for who knows how long!!! Yikes!!!
    We replaced it yesterday with a fresh mid, and I used a bunch of the red loctite on that darn bolt this time.
    Now I will check for this every time. Thank you
  3. Thanks W2F a V-King thanked for this post
  4. #33
    I had a sea star end cap loosen and come off at 104mph. I let out and the whole boat turned and went bow high. It got real quiet till it came back down I hit the gas it straitened back out I idled back to ramp. Closest I've ever been to getting wet. Not fun. Now we locktite the threads and peen the edge so it can't unscrew. The end caps were installed by sea star it was a brand new pro system with a couple hundred miles on it.
  5. #34
    Aug 2006
    virginia
ID:	366703 these will appear on the back side...you wont even know it. Click image for larger version.
Name:	CRACKED MID SECTION 016.jpg
    nothing loose, just 3 or 4 ft chop.
  6. #35
    Aug 2015
    NE Tennessee
    All these pictures just drive home the need for a "flight" check first.
    Good to know, areas unseen needed to be checked.
    Sunkist.... Your boats name should be ADRENALINE !!
  1. Lucky Dog
    By steamengine6 in forum The Scream And Fly Lounge
    Last Post: 05-12-2011, 05:42 PM
  2. I got lucky
    By jeepster21 in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 05-17-2010, 06:03 AM
  3. You Might Get Lucky
    By HStream1 in forum The Scream And Fly Lounge
    Last Post: 12-10-2009, 04:21 PM
  4. lucky to be here.
    By stvhelm in forum The Scream And Fly Lounge
    Last Post: 10-23-2002, 07:20 AM
