Results 1 to 15 of 36
Thread: Land and Sea jack plate....
02-06-2017, 11:07 AM #1
Screaming And Flying!
- 15,135
- 416
- 1478
- 6110
- 11806
Motor on the L&S plate is not looking good. Fairly wore out. Has anyone found a replacement motor for one of these things? Have a part #? Saw a volvo penta that looks close if not right on. Have a call in to the place...Link here http://store.alternatorparts.com/par...e854525-3.aspx btw I have the newer one inside the slide plates...
02-06-2017, 01:18 PM #2
I got one years ago but Land&Sea were still selling boat parts, it looked the same as stock. Had the long sealed wire harness coming off the motor. If you find something that works let us know please.
02-06-2017, 01:56 PM #3
02-06-2017, 02:01 PM #4
- 15,135
- 416
- 1478
- 6110
- 11806
Closest I have found is the one I linked. I have the elec place sending me the measurements on it. It uses a 3'' dia. housing with the flat blade drive shaft. 2 mach screws go from top cap to hyd unit. And is a 2 wire. Other poss is to re-brush and clean up and see if it will work. No room for the ones you show.....It is a tight fit between the slides.
02-06-2017, 05:38 PM #5
If the outer case is alright, just take it to an starter/alternator repair shop for an armature turn and new brushes, I've had several done, even the motor starters
is gone
02-06-2017, 05:50 PM #6
- 15,135
- 416
- 1478
- 6110
- 11806
You are correct buzzin, that might be my best option. We have an elec rebuilder here local but it would cost twice what a new motor would cost. Still looking for a new one I can use. Old S&F thread sez it is a convertible top motor for a chrysler car?
02-06-2017, 06:30 PM #71980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
olboatman liked this post
02-06-2017, 06:34 PM #8
- 15,135
- 416
- 1478
- 6110
- 11806
Yeah, the old one lasted for 30+ yrs. So, I would like to go with something real close, or as buzzin said, re-build. Just one of those things to deal with when your junk is old....The one in the link on the 1st post looks to be real close....Just need some specs.
02-06-2017, 07:01 PM #91980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
02-07-2017, 08:19 AM #10
- 15,135
- 416
- 1478
- 6110
- 11806
After some looking it seems the sea star power steering uses the same motor. Can't find a after market one tho. Yet.....
02-07-2017, 10:35 AM #11
I have one of these motor that works, On mine, the pump was rotten beyond repair. Could sell it to you if you want it.
Glastron GT 150 W OMC 140
Glastron GT150 w OMC 235
Hydrostream Vision with 2.0l 135
Hydrostream HST w 3.0L 225
I know two things that are infinite, the Universe and Human's Stupidity, although I am not sure about the first one.
02-07-2017, 10:57 AM #12
- 15,135
- 416
- 1478
- 6110
- 11806
Just dropped my old one off at the rebuilders. He said no problem..Lets hope it works out. Thanks for the offer, dompie. PM sent...
02-07-2017, 11:43 AM #13
Member
- Feb 2013
- ME
- 43
The motor on the Model 600 L&S plate is a late 70's/early 80's OMC trim pump.
02-07-2017, 12:33 PM #14
- 15,135
- 416
- 1478
- 6110
- 11806
02-07-2017, 05:15 PM #15
Land n sea jack plate
By Cal 47 in forum Misc. Parts and AccessoriesReplies: 4Last Post: 08-19-2015, 03:42 PM -
Land & Sea Jack Plate
By 81-21Shadow in forum Technical DiscussionReplies: 7Last Post: 07-17-2012, 11:37 AM -
Land & Sea Jack plate
By Johan_H in forum Props, Setup, and RiggingReplies: 5Last Post: 04-18-2011, 10:09 AM -
Land&Sea jack plate
By FreaK in forum Technical DiscussionReplies: 4Last Post: 09-04-2001, 12:09 PM
