Results 1 to 15 of 21
    Apr 2016
    Cayman Islands/Miami Florida
    What Sparkplugs 260 use?
    What sparkplugs do the mercury 260 use with 34cc heads?
    BUHW.
    Mar 2010
    houston, tx
    Some also use bpz
    charlotte,nc
    Br9-hs-10
    death is certain; life is not
    Jun 2008
    Sardis Lake Oklahoma
    I've used NGK - BR9HS gapped on .035 since 1995 except for Winter Months or if I'm expecting o do a lot of idling then I'll go a step hotter to a BR8HS!
  6. Likes Go Time, ChrisCarsonMarine liked this post
    Folsom, Cal
    If I remember right my late model 260 came with BUZHW?
    "Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
    2007 Sportsmen Driver of the Year
  8. Likes 25two.stroke liked this post
    The Z plugs were for electrical interference issues, rarely needed but 3 times the price.
  10. Likes WillySteve liked this post
    TX......somewhere?
    this if digital....
    Quote Originally Posted by stoker2001 View Post
    buhw if non digital.......
    Jun 2008
    Yes, they do but IMO the Gapable plugs seem to work better. Also you can't read a surface gap plug!
  13. Likes David Borg liked this post
    Dec 2011
    Ludington michigan,on the shore
    Don't remember why, but i've been running BPZ8H-N-10 with good luck.No fouling and no holes.
    charlotte,nc
    You guys can use the $6 spark plugs if you want, but the BR9-HS 10 (B9HS-10 for carb motors) are about $2 at Auto Zone or Advance and work just as well or better. AND you can read them!!!
  16. #12
    Quote Originally Posted by nelson edens View Post
    Those solid steel ends or the aluminum thread on ends?
    TX......somewhere?
    still tryin' ta figure out why ya'll buy so many anyway... can't remember ever wearin' out a spark plug.....
  18. Thanks KIRCHNER thanked for this post
  19. #14
    The old l6 motors would burn the Centre electrode to the diameter close to a pin. V6s not.
  20. Likes WillySteve liked this post
  21. #15
    I've been using bu8h's for ever. + if you ever got on the bad side of that huge coil they put on the inline distributor motors you'd know why they would burn down spark plugs lol.
  1. Sparkplugs 4 a Pro Max
    By Enticer1 in forum Technical Discussion
    Last Post: 10-11-2012, 08:46 AM
  2. Mercury Tech: Sparkplugs for 300x
    By off da hook in forum Technical Discussion
    Last Post: 06-15-2010, 09:43 AM
  3. What sparkplugs do I use for OMC V8 4.0??
    By kimswang in forum Technical Discussion
    Last Post: 05-21-2007, 04:15 PM
  4. 280 sparkplugs????
    By popslavaz in forum Technical Discussion
    Last Post: 08-09-2005, 08:24 PM
  5. Sparkplugs for 260?
    Last Post: 11-22-2002, 11:20 AM
