Results 1 to 15 of 17
    Massachusetts
    1980 2.4 225 modifications?
    hello everyone
    i have a 1980 2.4 225 merc
    i am looking to get some more out of it
    i want to modify it without going over the too. i am running it on a 1980 hydrostream vector all recored and solid transom. i am using a 1.87 gearcase woth land and sea lwp
    thank you all for any advice
    -Bob
    1989 Hydrostream Vector "Spongebob" 78mph
    1980 Hydrostream Vector "Ole Blue" 104mph
    1982 Allison GT20 "Red Eagle" 92mph
    1977 Hydrostream Viper "Hornet" 105mph
    1990 Mirage Jaguar 106mph
    1989 Hydrostream V-King YT "White Lightning" 91mph
    1991 Stv Procomp "$hitbox" 90mph
    Get a nicer trailer.
    Dec 2011
    Ludington michigan,on the shore
    Check the carbs,make sure it still has the WH15,cut the heads for 145psi cut the tuner back to 6 1/2" on the long side. If none of this helps,then go trailer shopping
  4. Likes spongebob440, 3rd Gen liked this post
    May 2009
    MASS
    Trailers are Cheap Go for it Bob !! outasite whats the spec for the 145 psi on the heads ? And Happy New you to you and Pete !
    Quote Originally Posted by outasite View Post
    May 2009
    MASS
    Look at your picture on your post the boats riding on its side that will slow you down for sure !! L O L
  7. Likes pkstv, 1BadAction liked this post
    Dec 2011
    Well if ya got an 80 PH it's a gen 1.that makes it a HEMI!!! From what I remember 31cc to start,some went to 29cc and more.The 2.4 off shores of 78/9 vintage were cut .100 @ factory and would yield around 145psi and called for avfuel
  9. Thanks 3rd Gen thanked for this post
    Likes 3rd Gen liked this post
    Dec 2011
    Or you could put a pair of first gen 2L heads on it.
  11. Likes 3rd Gen liked this post
  12. #8
    OR......buy a bigger paddle
  13. Likes 3rd Gen liked this post
  14. #9
    Sep 2006
    Carson reeds really cleaned up idling.
  15. #10
    Sep 2006
    Key Largo, Fl
    Wont fit,different bolt pattern,Chris
  16. #11
    TX......somewhere?
    when dealin' with 1st gen heads/block be very careful... they (bolt bosses, threads) don't like a bunch a on and off stuff... make sure both surfaces are "flat"....
    even with tha added comp ya not gonna see much.... i ran those for several years back in tha day at 140/145 22 degrees with 91/93 with no problems.....
    came with 5's and 20's also.... 20's are good...
    Massachusetts
    the serial number is 5929399 if this helps figure out exactpy what it is
    thank you Bob!
  18. #13
    TX......somewhere?
    '80/'81 225, first gen.
  19. #14
    Dec 2011
    Those were the first of the horizontal seven petal reed motors.They were strong for the time.The down side was the head bolts pulling on the cylinder bores.If the heads got pulled a few times the bores would get pulled out of round,and the threads tended to strip out.The 2L 1750 with the steel liners diden't seem to suffer as bad.I was thinking that all gen 1 head bolt patterns were the same,2.4 and 2.0 but its been 35 years. Get her runnin and bring it to the romp!!
  20. #15
    Massachusetts
    she runs like a beast!! seen 83mph on the vector with just my dad driving in the bay. Doing solid mounts and new base gaskets and she will be at the romp!! Hopefully along with my vector (stringer comp layup)bwhen it gets done. HOPEFULLY!!!! i needa get back to rippin core out again. ive been slacking lol
    -Josh
  1. IllinoisRiverRat 1980 Champion Swift/1980...Prop setup
    By IllinoisRiverRat in forum Props, Setup, and Rigging
    Last Post: 07-31-2013, 09:57 PM
  2. First modifications
    By unclebuck134 in forum Technical Discussion
    Last Post: 07-26-2009, 10:23 PM
  3. MOD VP CLE Modifications?
    By jaroot in forum Technical Discussion
    Last Post: 10-17-2003, 02:11 PM
  4. 225 PM modifications
    By Morespeed4Me in forum Technical Discussion
    Last Post: 02-23-2002, 09:22 AM
