Page 6 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 76 to 90 of 105
  1. #76
    Mar 2004
    Brooklyn Park, MN
    Quote Originally Posted by Varmint View Post
    Noodles are like $2 each at wallyworld apparently they take epoxy resin well as a core material and they cut em in half and stick em down in the wedge of the sponson,dunno never tried it.
    Interesting
  2. #77
    Sitka, Alaska
    In case someone is reading that like I just did,..... DO NOT core your boat with pool noodles!!!!
    Ron Pratt
    '91 Virage "The LAST Virage" 300 ProMax
    1989 Voyager XT 200R
  3. #78
    Jun 2009
    Bristol, Connecticut
    In my RC boats I use pool noodles for flotation and also flat sheets of polyethylene foam
  4. #79
    Quote Originally Posted by Aaronhl View Post
    OK how about this one guys, should I do carpet OR "paint" for the inside floor?
    I sprayed mine light grey with SEM 39650 "tintable" truck bedliner. It stays a little bit "rubbery"... makes a nice non-slip, easy to wash out, durable floor.
    http://www.autobodytoolmart.com/sem-...0-p-15344.aspx
    I like the stuff, it just didn't "cover" the way I expected and everything shows through just like paint... I wish I had done more prep (like clipping stray fiberglass strands).
    I bought their undercoating gun to apply it:
  5. #80
    Dec 2011
    Ottawa
    Quote Originally Posted by AlaskaStreamin View Post
    Haha i'm not recommending anybody epoxy pool noodles in their hull, just read it on several boards, so just sayin' happy new year to all you fella's.
  6. #81
    Sitka, Alaska
    Oh I knew what you were saying. Just didn't want a noob to read it wrong and buy out wally mart.
    Ron Pratt
  7. #82
    Dec 2011
    Ottawa
    Lol
  8. #83
    Jun 2009
    Hi guys I am back, been working on the virage, here is a sneak peak will post more pictures over the next few weeks...clamps just dry fitting
    if anyone wants those clamps I will sell you several
  9. Likes tunnels liked this post
  10. #84
    Jul 2007
    Have lived and worked in New Zealand ,Tahiti,Australia,Japan , south Korea, And now Suzhou in China
    wow nice work !!!
    Dont forget to finish all your edges etc and drill a zillion bleed holes to let the air pockets bleed out and any surplus resins etc all over when you do the final clamp together !
    Its possible to clamp that transom down simply by using vacuum bag and that's cool !!
  11. #85
    Jun 2009
    Here were the 3 pieces I put together for the transomClick image for larger version.
  12. #86
    Jun 2009
    Quote Originally Posted by tunnels View Post
    wow nice work !!!
    I wish I was setup for vacuum baggin
  13. #87
    Jul 2007
    Vac bagging a wooden transom directly onto wet glass need 3 layers of 450 gram csm well wet out and the plywood pacer need 5 mm holes drill all over at about 80mm spacing . during the suck down the transom squashes the glass compresses and the resin bleeds though to the face side ,also if there are any voids within the construction of the plywood packer the resin penetrates the bleed holes allow the penetration of resin into and fills the voids inside the layers of ply 1, Places where veneers have small gaps or knot holes and the like !! the other up side its one hell of a lot harder for water to soak the ply packer so transom lasts way longer than normal .
    One place when we had twin stern drives we sucked the two packers at the same time . When the hull was lifted out and the hole cut it had completely soaked and sealed with resin all and every where !!, but the very edge of the hole was still glassed over and gel coated as a extra precaution ,Big boats sit in the water 11 1/2 months of the year so anything that will slow down water getting in any where is always a huge help.
    DONT FORGET TO PRIME AND ALLOW TO SOAK THE BACK SIDE BEFORE YOU FIT ITAGAINST WHAT EVER YOU STICKING IT WITH THEN CLAMP
    YOU MIGHT ALSO NEED SOME FINE THIN WEDGES TO HAMMER IN FROM EACH SIDE BETWEEN THOSE ARMS AND THE PACKER AS THE ARMS WILL BEND AT THE FURTHERST END FOR SURE ! EVEN 2X4 BOX SECTION STEEL BENDS
    GOOD LUCK ANYWAY !!
  14. #88
    Jun 2009
    What do you mean arms? Do you mean the lower corner? I was thinking about cutting some wood to put in there with thickened resin before I fiberglass over
  15. #89
    Jul 2007
    The 4 arms of those clamps you made !!
    So what sort of a mix you anticipate using as adhesive to stick the wood to the glass ??
  16. #90
    Jun 2009
    Ahhh gotcha, I can get them pretty tight though because the tops spread and put pressure on the bottom of the transom
    i have raka slow epoxy for the boat
